Hi to all,
Have this CORSAIR Seagate family, have this in terminal in reading some sectors in the disk.
Try to save LDR from the disk but it says terminal error ???
But in terminal i can see the LOG.
SFI
SFI
SFI
AT Er 00 Nwt Er 47 RdWr 0487c.01.0298
ATA St d0 Er 00 Op c8 e, 338b51e,00 af 03
Niwot: 0338b51e 18 0338b51e.0.0c0 8000 2d44 1400 0000
DiskAccess ReadSector EC=47 at 0046ea.01.0298
CE Log ErrCode=47 LBA=338b577 Type=5 Add To Pending 338b577
(S)
8d5SAT Er 00 Nwt Er 47 RdWr 0487c.01.0317
ATA St d0 Er 00 Op 20 e, 338b5f6,01 00 55
Niwot: 0338b5f6 18 0338b5f6.0.0c0 8000 1e0d 0800 0000
DiskAccess ReadSector EC=47 at 0046ea.01.0317
CE Log ErrCode=47 LBA=338b5f6 Type=5 Add To Pending 338b5f6
NiwotErrorLBA 0338b5f6
AT Er 00 Nwt Er 47 RdWr ffffffff.01.00ee
ATA St d1 Er 10 Op 20 e, 338b5f6,01 00 55
Niwot: 30010000 ac 30010000.0.038 0000 10ed d901 01e0
(S)SAT Er 00 Nwt Er 47 RdWr 0487c.01.02b3
ATA St d0 Er 00 Op 20 e, 338b592,01 00 55
Niwot: 0338b592 18 0338b592.0.0c0 8000 1cb0 0800 0000
DiskAccess ReadSector EC=47 at 0046ea.01.02b3
CE Log ErrCode=47 LBA=338b592 Type=5 Add To Pending 338b592
NiwotErrorLBA 0338b592
ATA St d1 Er 10 Op 20 e, 338b592,01 00 55
(S)SAT Er 00 Nwt Er 37 RdWr 0487c.01.0298
ATA St d0 Er 00 Op 20 e, 338b577,01 00 55
Niwot: 0338b577 18 0338b577.0.0c0 8000 1f1d 0800 0000
CE Log ErrCode=37 LBA=338b577 Type=5 Add To Pending 338b577
NiwotErrorLBA 0338b577
AT Er 00 Nwt Er 37 RdWr ffffffff.01.00ee
ATA St d1 Er 40 Op 20 e, 338b577,01 00 55
SFI
SFI
SFI
Anyone happen this ?
ZeBong
ST 9120817 AS - CE Log ErrCode=37
Re: ST 9120817 AS - CE Log ErrCode=37
I got the same problem too here. I dont why it report as terminal error but I still can see terminal output as well and can send any command to tyhe Drive. I need to try several time to have a good connection. IS this problem with the USB connection or just a bug from UDMA.
I got no idea
I got no idea
i made the detect hdd transfer rate, them i could save the LDR.
Also i notice that are two pending bugs in the utility, but ace is not giving any new manual to the new updates
is not good.
is not good.
