I just had a case with an ST3320820AS 7200.10 with a bad bearing and a lot of spots on the surfaces from a drop on the ground.
I managed it to read quite fast (in the good areas) until this morning it read very slowly (i.e a maybe 10 sectors per second)
My UDMA machine showed a CE Log error.
In this forum I only found a way around it with DataExtractor - which I don't have unfortunately. So I googled a bit and found that you can fix it with
in T mode with <CTRL-R> to load the cert code followed by a T4E to fix the CE Log error or the "pending bug".
After a few seconds the test result came back ok and I repowered the drive.
Now it's fast again.
I thought I should share it here because I could not find it here yet.
Boe
