WD2000JS-00MHB0 translator failed after head disable
Nova
Postby Nova » 02.06.09, 15:00
Hi Guys
I have WD2000JS-00MHB0 (HAWK) with 1 head failed, disabled through headmap and no longer clicking, check all modules and found translator mod 31 error.
The problem is, i cannot regenerate translator without all functioning heads, if i enable the previously disabled head the drive clicking continuously.
DE head map building failed after 80% with a message "Error execute=Translator regeneration error Techno CMD sending error Device Error Detected: "DM TRANSLATION OUT OF RANGE"
Head exchange does not work with this drive, as soon as head 1 is turn off the translator failed i.e cant clone.
Is there a work around on Hawk?
Thank you.
dmarques
Re: WD2000JS-00MHB0 translator failed after head disable
Postby dmarques » 02.06.09, 16:01
PM me.
Nova
Postby Nova » 02.06.09, 17:14
datalabace wrote:PM me.
can't pm you for some reason there's no PM button :)
did you enable your "Allow users to send you private messages:"?
dmarques
Postby dmarques » 03.06.09, 18:13
You're right! But I do have that option enabled. I think the problem is with the forum itself.
Here's my email: datalab.ace at gmail dot com
Nova
Postby Nova » 04.06.09, 07:15
datalabace i have sent you an email
