Hitachi AAVA NV-Ram rebuild
ZeBong
Postby ZeBong » 15.05.09, 15:54
i have this disk that the PCB had a NV-ram corrupeted.
So i found i donor PCB with the same two lines and change it.
Now i can not get ID off the disk.
And i can make a SA Structure Test.
I try also a nv-ram adjustement, it work reading the nv-ram from the sa but when i save the NV-ram from adjustemtn i can not get the ID off the disk...
So what i am doing wrong where ?
Test : NV-RAM adjustment (SA search)
To vary.................. : SA Top
from..................... : 0x6C1E
to....................... : 0x6C1E
Working folder........... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\AVVA\AVVA\Data\NV-RAM adaptation
NV-RAM reading.......................... : Ok
Saving NV-RAM to file ( NV-RAM_Org.nvr ).............................. : Ok
NV-RAM ID............................... : VA2OA52A
Prevention full FW boot................. : Ok
Checking at current values.............. : Ok
SA read for value....................... : 0x6C1E
Saving NV-RAM to file ( NV-RAM_Adapted_For_Chk.nvr ).................. : Ok
NV-RAM ID............................... : VA2OA52Á
Restoring full FW boot.................. : Ok
Saving NV-RAM to file ( NV-RAM_Adapted.nvr ).......................... : Ok
Re: Hitachi AAVA NV-Ram rebuild
Postby AJ2008 » 25.05.09, 19:23
You may be doing everything OK, but possibly there could be some SA damage. Do any modules have any apparent damage? Also, after NVRAM adjustment can sector edit be launched?
dmarques
Postby dmarques » 26.05.09, 12:15
I don't think your problem is related with NV-RAM, but with some open modules damaged.
By the way, when you replace PCB, have you replaced NV-RAM as well to the new PCB ?
ZeBong
Postby ZeBong » 27.05.09, 22:57
The problem is the NV-ram,
This is the original PCB that i have used in other disk and saved the nv-ram to this PCB.
I don't need the data just to understand how it works the nv-ram adjustment.
or try to save the nv-ram from the modules.
