MHX2300BT weird
aviko
MHX2300BT weird
Postby aviko » 10.05.09, 20:54
Drive is recognized, id reads. When I launch utility, MHX family is active and "Start utility" is active too. but if i change family to MHV and go back to MHX "Start utility" is inactive. When I restart utility and enter as MHX2xxxBT in log i see that MHV family was choosen.
here is log from utility.
Code: Select all
Selected family......................... : MHV2xxxAT/AH
Selected model.......................... : MHV2060AT
Model by HDD ID......................... :
Reading module table from SA...
Module table is loaded
Loading : HS, head map module......................................... : Ok
Loading : PL, single sector defect list and zone allocation table modu : Error
Error................................................................. : PL: Invalid zones distribution info (ZoneNo)!
Test  : SA structure test
LOADING MODULES
Module 0104........................................................... : Ok
Module 0120........................................................... : Ok
Module 0106........................................................... : Ok
Module 0122........................................................... : Ok
Module 01E1........................................................... : Ok
Can`t read module 013D from HDD
Module 013D........................................................... : Error
Can`t read module 013E from HDD
Module 013E........................................................... : Error
Can`t read module 013F from HDD
Module 013F........................................................... : Error
Can`t read module 0140 from HDD
Module 0140........................................................... : Error
Can`t read module 015A from HDD
Module 015A........................................................... : Error
Can`t read module 015B from HDD
Module 015B........................................................... : Error
Module 0101........................................................... : Ok
Module 01E8........................................................... : Ok
Module 0107........................................................... : Ok
Module 01E2........................................................... : Ok
Module 0108........................................................... : Ok
Can`t read module 010C from HDD
Module 010C........................................................... : Error
Can`t read module 010D from HDD
Module 010D........................................................... : Error
Module 010A........................................................... : Ok
Module 012D........................................................... : Ok
Module 012B........................................................... : Ok
Module 012A........................................................... : Ok
Module 0109........................................................... : Ok
Module 0131........................................................... : Ok
Module 0127........................................................... : Ok
Module 0132........................................................... : Ok
Module 0128........................................................... : Ok
Module 0145........................................................... : Ok
Module 0170........................................................... : Ok
Module 0129........................................................... : Ok
Module 0137........................................................... : Ok
Module 01E9........................................................... : Ok
Module 01EA........................................................... : Ok
Can`t read module 01ED from HDD
Module 01ED........................................................... : Error
Module 016C........................................................... : Ok
Can`t read module 0150 from HDD
Module 0150........................................................... : Error
Can`t read module 0155 from HDD
Module 0155........................................................... : Error
Can`t read module 0154 from HDD
Module 0154........................................................... : Error
Module 0151........................................................... : Ok
Module 0152........................................................... : Ok
Can`t read module 0157 from HDD
Module 0157........................................................... : Error
Can`t read module 0158 from HDD
Module 0158........................................................... : Error
Module 0102........................................................... : Ok
Module 010B........................................................... : Ok
Module 0105........................................................... : Ok
Module 010E........................................................... : Ok
Module 0130........................................................... : Ok
Module 0135........................................................... : Ok
Module 0136........................................................... : Ok
Module 012E........................................................... : Ok
Module 0141........................................................... : Ok
Module 0142........................................................... : Ok
Module 01A0........................................................... : Ok
Module 0103........................................................... : Ok
Module 01E3........................................................... : Ok
Module 01A9........................................................... : Ok
Module 01AA........................................................... : Ok
Module 01AB........................................................... : Ok
Module 01AC........................................................... : Ok
Module 01AD........................................................... : Ok
Module 0123........................................................... : Ok
Drive not ready
Module 01FA........................................................... : Error
Module 01EE........................................................... : Ok
Module 01D0........................................................... : Ok
Module 01D1........................................................... : Ok
Module 01D8........................................................... : Ok
Module 01D9........................................................... : Ok
Module 01DA........................................................... : Ok
Module 01DB........................................................... : Ok
Module 01DC........................................................... : Ok
Module 01DD........................................................... : Ok
Module 01DE........................................................... : Ok
Module 01DF........................................................... : Ok
Module 01E4........................................................... : Ok
Module 01E5........................................................... : Ok
Module 01E6........................................................... : Ok
Module 01E7........................................................... : Ok
Module 0156........................................................... : Ok
Module 0110........................................................... : Ok
Module 0111........................................................... : Ok
Module 0112........................................................... : Ok
Module 0113........................................................... : Ok
Module 0114........................................................... : Ok
Module 0116........................................................... : Ok
Module 0117........................................................... : Ok
Module 0118........................................................... : Ok
Module 0119........................................................... : Ok
Module 011E........................................................... : Ok
Module 0166........................................................... : Ok
Module 0167........................................................... : Ok
Module 0168........................................................... : Ok
Module 016B........................................................... : Ok
Module 016D........................................................... : Ok
Module 011C........................................................... : Ok
Module 011F........................................................... : Ok
Module 0121........................................................... : Ok
Module 0160........................................................... : Ok
Module 0161........................................................... : Ok
Module 0162........................................................... : Ok
Module 0163........................................................... : Ok
Module 0164........................................................... : Ok
Module 0165........................................................... : Ok
Module 01A1........................................................... : Ok
Module 01A2........................................................... : Ok
Module 0180........................................................... : Ok
Module 01C0........................................................... : Ok
Module 013A........................................................... : Ok
Module 011D........................................................... : Ok
Module 0169........................................................... : Ok
Module 016A........................................................... : Ok
Module 0115........................................................... : Ok
Module 016F........................................................... : Ok
Module 0124........................................................... : Ok
Can`t read module 01EB from HDD
Module 01EB........................................................... : Error
Module 0178........................................................... : Ok
Module 0179........................................................... : Ok
Module 017A........................................................... : Ok
Module 017B........................................................... : Ok
Module 017C........................................................... : Ok
Module 017D........................................................... : Ok
Can`t read module 017E from HDD
Module 017E........................................................... : Error
Can`t read module 017F from HDD
Module 017F........................................................... : Error
Module 01B8........................................................... : Ok
Module 01B0........................................................... : Ok
Module 01B1........................................................... : Ok
Module 01B2........................................................... : Ok
Module 01B3........................................................... : Ok
Module 01B4........................................................... : Ok
Module 01B5........................................................... : Ok
Can`t read module 01B6 from HDD
Module 01B6........................................................... : Error
Can`t read module 01B7 from HDD
Module 01B7........................................................... : Error
Module 0201........................................................... : Ok
Module 0204........................................................... : Ok
Module 0206........................................................... : Ok
Module 0207........................................................... : Ok
Module 0208........................................................... : Ok
Can`t read module 020C from HDD
Module 020C........................................................... : Error
Can`t read module 020D from HDD
Module 020D........................................................... : Error
Module 0220........................................................... : Ok
Module 0222........................................................... : Ok
Module 0227........................................................... : Ok
Module 022B........................................................... : Ok
Module 0237........................................................... : Ok
Module 0241........................................................... : Ok
Module 0242........................................................... : Ok
Can`t read module 0255 from HDD
Module 0255........................................................... : Error
Module 0256........................................................... : Ok
Module 02B0........................................................... : Ok
Module 02B1........................................................... : Ok
Module 02B2........................................................... : Ok
Module 02B3........................................................... : Ok
Module 02B4........................................................... : Ok
Module 02E0........................................................... : Ok
Module 02E1........................................................... : Ok
Module 02E2........................................................... : Ok
Module 02E5........................................................... : Ok
Module 02E6........................................................... : Ok
Module 02E7........................................................... : Ok
Module 02E8........................................................... : Ok
Module 02EA........................................................... : Ok
SA Test report:
Code: Select all
  ID :    Name : Importn.:   Source : Size : Read(sect) : Read :    Hdr : Description
0104 :      HS :    B    :      HDA :    5 :      5     :  Yes :     Ok : HS, head map module
0120 :      SP :         :      HDA :    8 :      8     :  Yes :     Ok : SP, Servo Parameters
0106 :      DT :   Ad    :      HDA :   96 :     96     :  Yes :     Ok : DT, translator module
0122 :      RR :    B    :      HDA :    7 :      7     :  Yes :     Ok : RR, Retry Table
01E1 :      GT :    B    :      HDA :   54 :     54     :  Yes :     Ok : GT, Geometry
013D :         :    B    :      HDA :  256 :      0     :   No :        : CODE overlay module
013E :         :    B    :      HDA :  256 :      0     :   No :        : CODE overlay module
013F :         :         :      HDA :  256 :      0     :   No :        :
0140 :         :         :      HDA :  256 :      0     :   No :        :
015A :         :         :      HDA :  512 :      0     :   No :        :
015B :         :         :      HDA :  256 :      0     :   No :        :
0101 :      DM :   Ad    :      HDA :  170 :    170     :  Yes :     Ok : DM/DU, translator module
01E8 :      RL :    B    :      HDA :    2 :      2     :  Yes :     Ok : RL, Reassign Log
0107 :      SI :    B    :      HDA :    5 :      5     :  Yes :     Ok : SI, logical parameters module
01E2 :      AT :    B    :      HDA :    1 :      1     :  Yes :     Ok : AT, ATA Parameters
0108 :      SN :    B    :      HDA :    1 :      1     :  Yes :     Ok : SN, serial number module
010C :      SM :    B    :      HDA :    1 :      0     :   No :        : SM, Master password module
010D :      SU :    B    :      HDA :    1 :      0     :   No :        : SU, User password module
010A :         :    B    :      HDA :    1 :      1     :  Yes :     Ok : SMART module, Thresholds
012D :      FA :    C    :      HDA :    8 :      8     :  Yes :     Ok : FA, log module
012B :      TL :         :      HDA :    2 :      2     :  Yes :     Ok :
012A :         :    C    :      HDA :    1 :      1     :  Yes :     Ok : log module (Shock log)
0109 :         :    C    :      HDA :    1 :      1     :  Yes :     Ok : SMART module, Values
0131 :      RE :    C    :      HDA :    8 :      8     :  Yes :     Ok : RE, log module (UncRdErrLog)
0127 :         :    C    :      HDA :    1 :      1     :  Yes :     Ok : log module (Error lo)
0132 :      WE :    C    :      HDA :    8 :      8     :  Yes :     Ok : WE, log module (UncWrErrLog)
0128 :         :    C    :      HDA :    1 :      1     :  Yes :     Ok : log module (Selftest)
0145 :         :    C    :      HDA :    1 :      1     :  Yes :     Ok : SelectSelfTest
0170 :         :    B    :      HDA :   64 :     64     :  Yes :     Ok : log module
0129 :         :    C    :      HDA :    2 :      2     :  Yes :     Ok : log module (Ext.Selftest)
0137 :         :         :      HDA :   64 :     64     :  Yes :     Ok :
01E9 :      BE :    B    :      HDA :    3 :      3     :  Yes :     Ok : BE, BCRCErrLog
01EA :      CT :    B    :      HDA :    2 :      2     :  Yes :     Ok : CT, CacheTune
01ED :      VT :         :      HDA :    2 :      0     :   No :        :
016C :      FH :         :      HDA :    7 :      7     :  Yes :     Ok :
0150 :         :    C    :      HDA :   11 :      0     :   No :        : S.M.A.R.T. Values + FA
0155 :      SM :         :      HDA :    2 :      0     :   No :        :
0154 :      FA :    C    :      HDA :   14 :      0     :   No :        : S.M.A.R.T. Values + ID=2A
0151 :      RE :    C    :      HDA :    9 :      9     :  Yes :     Ok : RE + ID=27
0152 :      WE :    C    :      HDA :    9 :      9     :  Yes :  Error : ID=2A + WE
0157 :      FA :         :      HDA :   16 :      0     :   No :        :
0158 :      FA :         :      HDA :   10 :      0     :   No :        :
0102 :      PL :   Dd    :      HDA :  256 :    256     :  Yes :     Ok : PL, single sector defect list and zone allocation table module
010B :         :    B    :      HDA :    1 :      1     :  Yes :     Ok : SMART module, Values(reset)
0105 :      FI :    D    :      HDA :    1 :      1     :  Yes :     Ok : FI, manufacturer information module
010E :      CI :    D    :      HDA :    1 :      1     :  Yes :     Ok : HDD hardware list module (text log)
0130 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
0135 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
0136 :         :         :      HDA :   51 :     51     :  Yes :     Ok :
012E :         :         :      HDA :    5 :      5     :  Yes :     Ok :
0141 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
0142 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
01A0 :      FT :         :      HDA :    2 :      2     :  Yes :     Ok :
0103 :      TS :   Ad    :      HDA :   29 :     29     :  Yes :     Ok : TS, P-List, track defect list module
01E3 :      DL :         :      HDA :    2 :      2     :  Yes :     Ok :
01A9 :      SE :         :      HDA :    8 :      8     :  Yes :     Ok :
01AA :      SE :         :      HDA :    2 :      2     :  Yes :     Ok :
01AB :      SE :         :      HDA :    2 :      2     :  Yes :     Ok :
01AC :      SE :         :      HDA :    2 :      2     :  Yes :     Ok :
01AD :      SE :         :      HDA :    2 :      2     :  Yes :     Ok :
0123 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
01FA :         :         :      HDA :    1 :      0     :   No :        :
01EE :         :         :      HDA :    1 :      1     :  Yes :     Ok :
01D0 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
01D1 :         :         :      HDA :    1 :      1     :  Yes :     Ok :
01D8 :      PS :         :      HDA :   72 :     72     :  Yes :     Ok :
01D9 :      PS :         :      HDA :   48 :     48     :  Yes :     Ok :
01DA :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01DB :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01DC :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01DD :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01DE :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01DF :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01E4 :      PS :         :      HDA :   24 :     24     :  Yes :     Ok :
01E5 :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01E6 :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
01E7 :      PS :         :      HDA :    8 :      8     :  Yes :     Ok :
0156 :         :         :      HDA :    2 :      2     :  Yes :     Ok :
0110 :         :    B    :      HDA :   32 :     32     :  Yes :     Ok : SCH
0111 :         :    B    :      HDA :    9 :      9     :  Yes :     Ok : SEQ
0112 :         :    B    :      HDA :    2 :      2     :  Yes :     Ok : WTP
0113 :         :    B    :      HDA :    1 :      1     :  Yes :     Ok : END
0114 :         :    B    :      HDA :    4 :      4     :  Yes :     Ok : ECT
0116 :         :    B    :      HDA :   32 :     32     :  Yes :     Ok : SVE
0117 :      TA :    B    :      HDA :   12 :     12     :  Yes :     Ok : TA
0118 :         :    B    :      HDA :    9 :      9     :  Yes :     Ok : DPT
0119 :         :         :      HDA :   33 :     33     :  Yes :     Ok :
011E :         :    B    :      HDA :  128 :    128     :  Yes :     Ok : OSC
0166 :      PP :         :      HDA :    6 :      6     :  Yes :     Ok :
0167 :         :         :      HDA :   16 :     16     :  Yes :     Ok :
0168 :         :         :      HDA :    7 :      7     :  Yes :     Ok :
016B :         :         :      HDA :    1 :      1     :  Yes :     Ok :
016D :         :         :      HDA :  256 :    256     :  Yes :     Ok :
011C :         :    B    :      HDA :   64 :     64     :  Yes :     Ok : RRO
011F :         :    B    :      HDA :    8 :      8     :  Yes :     Ok : REC
0121 :      VG :    B    :      HDA :    7 :      7     :  Yes :     Ok : VG
0160 :         :    B    :      HDA :  136 :    136     :  Yes :     Ok : SR
0161 :         :         :      HDA :   16 :     16     :  Yes :     Ok :
0162 :         :    B    :      HDA :   40 :     40     :  Yes :     Ok : TR
0163 :         :         :      HDA :   18 :     18     :  Yes :     Ok :
0164 :         :         :      HDA :    5 :      5     :  Yes :     Ok :
0165 :         :         :      HDA :   40 :     40     :  Yes :     Ok :
01A1 :      HZ :         :      HDA :   68 :     68     :  Yes :     Ok :
01A2 :      GT :         :      HDA :   96 :     96     :  Yes :     Ok :
0180 :         :         :      HDA :   16 :     16     :  Yes :     Ok :
01C0 :         :         :      HDA :   10 :     10     :  Yes :     Ok :
013A :         :         :      HDA :  256 :    256     :  Yes :     Ok :
011D :         :         :      HDA :   80 :     80     :  Yes :     Ok :
0169 :         :         :      HDA :    3 :      3     :  Yes :     Ok :
016A :         :         :      HDA :  512 :    256     :  Yes :     Ok :
0115 :         :    B    :      HDA :  512 :    256     :  Yes :     Ok : ERR
016F :         :         :      HDA :   48 :     48     :  Yes :     Ok :
0124 :         :         :      HDA :   36 :     36     :  Yes :     Ok :
01EB :      WT :         :      HDA :    4 :      0     :   No :        :
0178 :      DT :         :      HDA :   12 :     12     :  Yes :     Ok :
0179 :      DT :         :      HDA :   12 :     12     :  Yes :     Ok :
017A :      DT :         :      HDA :   12 :     12     :  Yes :     Ok :
017B :      DT :         :      HDA :   12 :     12     :  Yes :     Ok :
017C :      DT :         :      HDA :   12 :     12     :  Yes :     Ok :
017D :      DT :         :      HDA :   12 :     12     :  Yes :     Ok :
017E :      DT :         :      HDA :   12 :      0     :   No :        :
017F :      DT :         :      HDA :   12 :      0     :   No :        :
01B8 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B0 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B1 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B2 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B3 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B4 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B5 :      GT :         :      HDA :    6 :      6     :  Yes :     Ok :
01B6 :      GT :         :      HDA :    6 :      0     :   No :        :
01B7 :      GT :         :      HDA :    6 :      0     :   No :        :
0201 :      DM :         :      RAM :  170 :    170     :  Yes :     Ok : DM/DU, translator module
0204 :      HS :         :      RAM :    5 :      5     :  Yes :     Ok : HS, head map module
0206 :      DT :         :      RAM :   96 :     96     :  Yes :     Ok : DT, translator module
0207 :      SI :         :      RAM :    5 :      5     :  Yes :     Ok : SI, logical parameters module
0208 :      SN :         :      RAM :    1 :      1     :  Yes :     Ok : SN, serial number module
020C :      SM :         :      RAM :    1 :      0     :   No :        : SM, Master password module
020D :      SU :         :      RAM :    1 :      0     :   No :        : SU, User password module
0220 :      SP :         :      RAM :    8 :      8     :  Yes :     Ok : SP, Servo Parameters
0222 :      RR :         :      RAM :    7 :      7     :  Yes :     Ok : RR, Retry Table
0227 :         :         :      RAM :    1 :      1     :  Yes :     Ok : log module (Error lo)
022B :      TL :         :      RAM :    2 :      2     :  Yes :     Ok :
0237 :         :         :      RAM :   64 :      1     :  Yes :     Ok :
0241 :         :         :      RAM :    1 :      1     :  Yes :     Ok :
0242 :         :         :      RAM :    1 :      1     :  Yes :     Ok :
0255 :      SM :         :      RAM :    2 :      0     :   No :        :
0256 :         :         :      RAM :    2 :      2     :  Yes :     Ok :
02B0 :      GT :         :      RAM :    6 :      6     :  Yes :     Ok :
02B1 :      GT :         :      RAM :    6 :      6     :  Yes :     Ok :
02B2 :      GT :         :      RAM :    6 :      6     :  Yes :     Ok :
02B3 :      GT :         :      RAM :    6 :      6     :  Yes :     Ok :
02B4 :      GT :         :      RAM :    6 :      6     :  Yes :     Ok :
02E0 :      SA :         :      RAM :    5 :      5     :  Yes :     Ok : SA, SA info
02E1 :      GT :         :      RAM :   54 :     54     :  Yes :     Ok : GT, Geometry
02E2 :      AT :         :      RAM :    1 :      1     :  Yes :     Ok : AT, ATA Parameters
02E5 :      PS :         :      RAM :    8 :      8     :  Yes :     Ok :
02E6 :      PS :         :      RAM :    8 :      8     :  Yes :     Ok :
02E7 :      PS :         :      RAM :    8 :      8     :  Yes :     Ok :
02E8 :      RL :         :      RAM :    2 :      2     :  Yes :     Ok : RL, Reassign Log
02EA :      CT :         :      RAM :    2 :      2     :  Yes :     Ok : CT, CacheTune
Report about table HS "HS, head map module"
ID...................................... : 0104
Length (sectors)........................ : 5
Heads map............................... : 0 1 2 3 4 5
Report about table TS "TS, Track defect list"
ID...................................... : 0103
Length (sectors)........................ : 29
Filter by heads......................... : Is not set up
Filter by zones......................... : Is not set up
Total number of defects................. : 306
The number of structural errors......... : 306
Distribution of defects by zones and heads :
zone   hd0   hd1   hd2   hd3   hd4   hd5
Module not loaded! ID = 0102; PL, single sector defect list and zone allocation table module
Error : PL: Invalid zones distribution info (ZoneNo)!
Report about table SN "SN, serial number module"
ID...................................... : 0108
Length (sectors)........................ : 1
Serial number........................... :         K205T8126UHA
Report about table FI "FI, manufacturer information module"
ID...................................... : 0105
Release date............................ : 08.01.13
Report about table CI "HDD hardware list module (text log)"
ID...................................... : 010E
000104  : CA06846-B20100SN
MEDIA   : HOYA            DQ7CRNK0616BCM
HEADS   : TDK             HLQDDZ4SA-7G611
HD-IC   : TI              7Z02E03M
DCM     : NIDEC           B17494O4000077
Module not loaded! ID = 010C; SM, Master password module
Error : Module storage : module ID 010C not loaded!
Module not loaded! ID = 010D; SU, User password module
Error : Module storage : module ID 010D not loaded!
Who does not know anything, must believe in everything
dmarques
Re: MHX2300BT weird
Postby dmarques » 11.05.09, 19:50
I had already the same problem and I'm still working on that drive.
aviko
Re: MHX2300BT weird
Postby aviko » 12.05.09, 06:54
Whats wrong with your disk? Mine is working correctly now. It clicked when i got it and there was sounds like huge scratch on platters (noise from inside of hdd was very similar to scratch but after opening hda there wasnt anything visible, even filter was clear. Surface on top is not used and hard to determine where problem is. Finally drive started to work and gives me 99% of data. amazing.
steven
Re: MHX2300BT weird
Postby steven » 12.05.09, 08:21
COOL
Return to “Fujitsu”
