I have a disc WD WD1600AABS-00PRA0.
PC3000 UDMA, does not recognize it.
SA does not have access.
Head does not recognize them, do not exist.
In order to change the HEAD, what donor I must have.
Thanks.
WD1600AABS
Re: WD1600AABS
Does the drive spins? Does it knock? Can you read ROM?
If you're sure it's heads get a drive from same model and head map.
- CarlosAdolfo
Re: WD1600AABS
Hi, datalabace
If the unit turns.
The ROM is read.
For interchange of heads, there is something more is due to do.
I look for the model and also its single family or I look for the family.
If the unit turns.
The ROM is read.
