WD3200JS-22PDB0 ROM gone
ft1bh
Postby ft1bh » 26.03.09, 14:08
Hi all,
I have a WD3200JS-22PDB0 (Raider I think, correct me if I'm wrong, 2060-701393-002 REV B is the PCB inprint) where most parts of the PCB are burnt including the ROM (at least it's unreadable) as well as bad heads (preamp).
I managed to swap heads and use a PCB from a donor drive. Now the drive is shown as ready but is not recognized (no Model, SN, FW or LBA) . I have full access to SA though. All modules are fine. The heads are not clicking.
Is there any way I can get a matching ROM (I believe this to be the culprit now)?
When I have a look at the donor modules most have a "400S?" in the first line, the FW is a 21.00.M21.
In most fo the patient's modules there is a "2119?" in the first line. Is this some kind of FW indicator?
I have tried several ROMs and so far the drive is getting "ready" (as in not clicking) with only 2 ROMs.
There is a new feature called ROM resatauration but I think this does not work with the Raider family.
Any help/ideas would be appreciated.
TIA,
ft1bh
DR_Ireland
Re: WD3200JS-22PDB0 ROM gone
Postby DR_Ireland » 01.04.09, 10:16
Hi ft1bh
I have resources for WDC WD3000JS-60PDB0 21.00M21, checked modules and most of them start with 2119. I could send you the ROM image if it would be of any help for you (remember to edit head map)
Pawel.
ft1bh
Postby ft1bh » 03.04.09, 15:09
Hello Pawel,
sorry for the delay, somehow my provider thought these notifications were spam.
Yes I would really like to get the ROM, maybe this is the key to solving the problem.
Can you send me the ROM to ft1bh at yahoo.de ?
Thank you very much in advance!
Postby AJ2008 » 03.04.09, 15:44
If SA is accessible and modules can be saved, you can select the option 'ROM rebuild from SA data' and point to your saved modules and the utiltiy should be able to generate a copy of the ROM from info in specific modules
ft1bh
Postby ft1bh » 03.04.09, 16:36
AJ,
I can't seem to find that option when I select the Raider family.
I have seen this under Tornado and some others so far but not Raider.
Am I missing something?
Boe
