Dear coleague's
I have a Western Digital, EAGLE HD, WD2500JD-55HBB0 with any destroyd modules. eg module 42 and more.
If anyone have this modules please send at my email: oyiecomova@yahoo.de
thank you very much.
Bruno
Modules for WD2500JD-55HBB0
Re: Modules for WD2500JD-55HBB0
Dear all
Thank You, ramserwis for the modules!
This HD is a little hard to recover....
I have all corrupt Modules replaced with the received. Any modules P-List and G-List i have filled with zeros, new checksum calc and header-check.
I dont now, what i forgot to check, but i dont could be read the user data.
New Translater regenerate works, but now acces to the user data.
I think i need help on this case.
After power on and start the "WD Caviar Cyl32(Sata)" Utility on the PC-3000UDMA, the
HD become ready:
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 87921
Head Count.............................. : 1
SPT..................................... : 900
ROM version............................. : 08.24D
ROM generation.......................... : 08.24D
Link table version...................... : 02.AA.
Heads configuration..................... : From map
The number of heads in use.............. : 6
Disabled heads.......................... : No
Head map................................ : 0,1,2,3,4,5
Service area:
Configuration loading................... : Ok
Master Password......................... : "WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD"
Translation overlay checking............ : Ok
next the Head test:
Heads test
Cylinder to test........................ : -25
Heads to test........................... : 0,1,2,3,4,5
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 3.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
SA Structure Test:
Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
41: 0 : As : -1: 0: 0: 2:Yes : Ok : Ok : A2 : : :Modules directory
41: 1 : As : -1: 1: 0: 2:Yes : Ok : Ok : A2 : : :Modules directory
19: 0 : B : -1: 0: 2: 20:Yes : Ok : Ok : C9 : : :Loaded part of microprogram code
19: 1 : B : -1: 1: 2: 20:Yes : Ok : Ok : C9 : : :Loaded part of microprogram code
1B: 0 : B : -1: 0: 23: 6:Yes : Ok : Ok : 4E : : :Loaded part of microprogram code
1B: 1 : B : -1: 1: 23: 6:Yes : Ok : Ok : 4E : : :Loaded part of microprogram code
1A: 0 : : -1: 0: 30: 4:Yes : Ok : Ok : CE : : :
1A: 1 : : -1: 1: 30: 4:Yes : Ok : Ok : CE : : :
1F: 0 : : -1: 0: 35: 1:Yes : Ok : Ok : BD : : :
1F: 1 : : -1: 1: 35: 1:Yes : Ok : Ok : BD : : :
AF: 0 : : -1: 0: 37: 5:Yes : Ok : Ok : FE : : :
AF: 1 : : -1: 1: 37: 5:Yes : Ok : Ok : FE : : :
A0: 0 : : -1: 0: 43: 17:Yes : Ok : Ok : 31 : : :
A0: 1 : : -1: 1: 43: 17:Yes : Ok : Ok : 31 : : :
A1: 0 : : -1: 0: 61: 29:Yes : Ok : Ok : 24 : : :
A1: 1 : : -1: 1: 61: 29:Yes : Ok : Ok : 24 : : :
A2: 0 : : -1: 0: 91: 9:Yes : Ok : Ok : 37 : : :
A2: 1 : : -1: 1: 91: 9:Yes : Ok : Ok : 37 : : :
A3: 0 : : -1: 0: 101: 13:Yes : Ok : Ok : 32 : : :
A3: 1 : : -1: 1: 101: 13:Yes : Ok : Ok : 32 : : :
42: 0 : B : -2: 0: 0: 2:Yes : Ok : Ok : 32 : : :Configuration (HDD ID)
42: 1 : B : -2: 1: 0: 2:Yes : Ok : Ok : 6B : : :Configuration (HDD ID)
43: 0 : Dd : -2: 0: 3: 360:Yes : Ok : Ok : 80 : :
-List (Primary defect list)
43: 1 : Dd : -2: 1: 3: 360:Yes : Ok : Ok : 34 : :
44: 0 : C : -2: 0: 364: 8:Yes : Ok : Ok : E0 : : :G-List (Grown defect list)
44: 1 : C : -2: 1: 364: 8:Yes : Ok : Ok : 8D : : :G-List (Grown defect list)
59: 0 : Dr : -2: 0: 373: 4:Yes : Ok : Ok : 4E : : :T-List (Track defect list)
59: 1 : Dr : -2: 1: 373: 4:Yes : Ok : Ok : 4E : : :T-List (Track defect list)
5A: 0 : : -2: 0: 378: 1:Yes :Error: Ok : AD : : :
5A: 1 : : -2: 1: 378: 1:Yes :Error: Ok : AD : : :
20: 0 : Ad : -2: 0: 380: 144:Yes : Ok : Ok : 6D : : :Translator
20: 1 : Ad : -2: 1: 380: 144:Yes : Ok : Ok : 6D : : :Translator
25: 0 : Ad : -2: 0: 525: 15:Yes : Ok : Ok : F2 : : :Translator
25: 1 : Ad : -2: 1: 525: 15:Yes : Ok : Ok : F2 : : :Translator
23: 0 : B : -2: 0: 541: 6:Yes : Ok : Ok : 88 : : :Translator
23: 1 : B : -2: 1: 541: 6:Yes : Ok : Ok : 88 : : :Translator
4C: 0 : As : -2: 0: 548: 2:Yes : Ok : Ok : AE : : :Adaptive data
4C: 1 : As : -2: 1: 548: 2:Yes : Ok : Ok : AE : : :Adaptive data
70: 0 : : -2: 0: 551: 2:Yes :Error: Ok : AD : : :
70: 1 : : -2: 1: 551: 2:Yes :Error: Ok : AD : : :
72: 0 : : -2: 0: 554: 2:Yes :Error: Ok : AD : : :
72: 1 : : -2: 1: 554: 2:Yes :Error: Ok : AD : : :
74: 0 : : -2: 0: 557: 2:Yes :Error: Ok : AD : : :
74: 1 : : -2: 1: 557: 2:Yes :Error: Ok : AD : : :
4D: 0 : As : -2: 0: 560: 2:Yes : Ok : Ok : 10 : : :Adaptive data
4D: 1 : As : -2: 1: 560: 2:Yes : Ok : Ok : 10 : : :Adaptive data
71: 0 : : -2: 0: 563: 2:Yes :Error: Ok : AD : : :
71: 1 : : -2: 1: 563: 2:Yes :Error: Ok : AD : : :
73: 0 : : -2: 0: 566: 2:Yes : Ok : Ok : FE : : :
73: 1 : : -2: 1: 566: 2:Yes : Ok : Ok : FE : : :
75: 0 : : -2: 0: 569: 2:Yes :Error: Ok : AD : : :
75: 1 : : -2: 1: 569: 2:Yes :Error: Ok : AD : : :
18: 0 : : -2: 0: 572: 2:Yes : Ok : Ok : 28 : : :Table 2 sectors
18: 1 : : -2: 1: 572: 2:Yes : Ok : Ok : 28 : : :Table 2 sectors
2B: 0 : B : -2: 0: 575: 25:Yes : Ok : Ok : 4F : : :S.M.A.R.T. Log
2B: 1 : B : -2: 1: 575: 25:Yes : Ok : Ok : 4F : : :S.M.A.R.T. Log
4E: 0 : As : -2: 0: 603: 32:Yes : Ok : Ok : 50 : : :Ver. Info Log
4E: 1 : As : -2: 1: 603: 32:Yes : Ok : Ok : B3 : : :Ver. Info Log
2C: 0 : B : -3: 0: 0: 10:Yes : Ok : Ok : 31 : : :S.M.A.R.T. Log
2C: 1 : B : -3: 1: 0: 10:Yes : Ok : Ok : 31 : : :S.M.A.R.T. Log
2E: 0 : B : -3: 0: 13: 24:Yes : Ok : Ok : F9 : : :Original S.M.A.R.T. Parameters table
2E: 1 : B : -3: 1: 13: 24:Yes : Ok : Ok : F9 : : :Original S.M.A.R.T. Parameters table
5B: 0 : : -3: 0: 40: 1:Yes : Ok : Ok : 40 : : :
5B: 1 : : -3: 1: 40: 1:Yes : Ok : Ok : 40 : : :
26: 0 : B : -3: 0: 44: 24:Yes : Ok : Ok : 72 : : :S.M.A.R.T. Parameters
26: 1 : B : -3: 1: 44: 24:Yes : Ok : Ok : 72 : : :S.M.A.R.T. Parameters
22: 0 : B : -3: 0: 71: 6:Yes : Ok : Ok : B1 : : :Translator
22: 1 : B : -3: 1: 71: 6:Yes : Ok : Ok : B1 : : :Translator
48: 0 : As : -3: 0: 80: 3:Yes : Ok : Ok : 3B : : :Adaptive data
48: 1 : As : -3: 1: 80: 3:Yes : Ok : Ok : 3B : : :Adaptive data
49: 0 : As : -3: 0: 86: 2:Yes : Ok : Ok : A6 : : :Adaptive data
49: 1 : As : -3: 1: 86: 2:Yes : Ok : Ok : A6 : : :Adaptive data
4A: 0 : As : -3: 0: 91: 4:Yes : Ok : Ok : 0D : : :Adaptive data
4A: 1 : As : -3: 1: 91: 4:Yes : Ok : Ok : 0D : : :Adaptive data
01: 0 : B : -3: 0: 98: 12:Yes : Ok : Ok : A4 : : :Loaded part of microprogram code
01: 1 : B : -3: 1: 98: 12:Yes : Ok : Ok : A4 : : :Loaded part of microprogram code
1C: 0 : : -3: 0: 118: 48:Yes : Ok : Ok : C9 : : :
1C: 1 : : -3: 1: 118: 48:Yes : Ok : Ok : C9 : : :
10: 0 : B : -3: 0: 174: 47:Yes : Ok : Ok : 05 : : :Loaded part of microprogram code
10: 1 : B : -3: 1: 174: 47:Yes : Ok : Ok : 05 : : :Loaded part of microprogram code
12: 0 : B : -3: 0: 229: 23:Yes : Ok : Ok : D2 : : :Loaded part of microprogram code
12: 1 : B : -3: 1: 229: 23:Yes : Ok : Ok : D2 : : :Loaded part of microprogram code
11: 0 : B : -3: 0: 255: 75:Yes : Ok : Ok : 95 : : :Loaded part of microprogram code
11: 1 : B : -3: 1: 255: 75:Yes : Ok : Ok : 95 : : :Loaded part of microprogram code
14: 0 : B : -3: 0: 333: 63:Yes : Ok : Ok : 07 : : :Loaded part of microprogram code
14: 1 : B : -3: 1: 333: 63:Yes : Ok : Ok : 07 : : :Loaded part of microprogram code
61: 0 : B : -3: 0: 399: 23:Yes : Ok : Ok : 96 : : :Flash rewriting microprogram (LDuCODE)
61: 1 : B : -3: 1: 399: 23:Yes : Ok : Ok : 96 : : :Flash rewriting microprogram (LDuCODE)
02: 0 : B : -3: 0: 425: 116:Yes : Ok : Ok : 7E : : :Loaded part of microprogram code
02: 1 : B : -3: 1: 425: 116:Yes : Ok : Ok : 7E : : :Loaded part of microprogram code
BF: 0 : : -3: 0: 549: 2:Yes : Ok : Ok : 6D : : :
BF: 1 : : -3: 1: 549: 2:Yes : Ok : Ok : 6D : : :
46: 0 : As : -3: 0: 554: 15:Yes : Ok : Ok : 5A : : :Adaptive data
46: 1 : As : -3: 1: 554: 15:Yes : Ok : Ok : 5A : : :Adaptive data
4B: 0 : As : -3: 0: 570: 3:Yes : Ok : Ok : 04 : : :Adaptive data
4B: 1 : As : -3: 1: 570: 3:Yes : Ok : Ok : 04 : : :Adaptive data
21: 0 : B : -3: 0: 574: 10:Yes : Ok : Ok : 94 : : :Event log
21: 1 : B : -3: 1: 574: 10:Yes : Ok : Ok : 94 : : :Event log
17: 0 : : -3: 0: 587: 2:Yes : Ok : Ok : 79 : : :Table 2 sectors
17: 1 : : -3: 1: 587: 2:Yes : Ok : Ok : 79 : : :Table 2 sectors
2A: 0 : B : -3: 0: 590: 33:Yes : Ok : Ok : 49 : : :S.M.A.R.T. Log
2A: 1 : B : -3: 1: 590: 33:Yes : Ok : Ok : 49 : : :S.M.A.R.T. Log
2F: 0 : B : -3: 0: 626: 8:Yes : Ok : Ok : 5D : : :S.M.A.R.T. Log (reserved)
2F: 1 : B : -3: 1: 626: 8:Yes : Ok : Ok : 5D : : :S.M.A.R.T. Log (reserved)
1E: 0 : : -3: 0: 635: 4:Yes : Ok : Ok : C0 : : :
1E: 1 : : -3: 1: 635: 4:Yes : Ok : Ok : C0 : : :
5C: 0 : : -3: 0: 640: 2:Yes : Ok : Ok : 21 : : :
5C: 1 : : -3: 1: 640: 2:Yes : Ok : Ok : 21 : : :
29: 0 : C : -8: 0: 280: 24:Yes : Ok : Ok : 6B : : :S.M.A.R.T. Parameters
29: 1 : C : -8: 1: 280: 24:Yes : Ok : Ok : 6B : : :S.M.A.R.T. Parameters
2D: 0 : C : -8: 0: 306: 24:Yes : Ok : Ok : 67 : : :S.M.A.R.T. Parameters
2D: 1 : C : -8: 1: 306: 24:Yes : Ok : Ok : 67 : : :S.M.A.R.T. Parameters
30: 0 : : -2: 0: 638: 12:Yes : Ok : Ok : AE : : :
30: 1 : : -2: 1: 638: 12:Yes : Ok : Ok : AE : : :
34: 0 : : -2: 0: 658: 47:Yes :Error: Ok : AD : : :
34: 1 : : -2: 1: 658: 47:Yes :Error: Ok : AD : : :
38: 0 : : -2: 0: 713: 6:Yes :Error: Ok : AD : : :
38: 1 : : -2: 1: 713: 6:Yes :Error: Ok : AD : : :
3C: 0 : : -2: 0: 722: 6:Yes :Error: Ok : AD : : :
3C: 1 : : -2: 1: 722: 6:Yes :Error: Ok : AD : : :
45: 0 : : -2: 0: 729: 15:Yes :Error: Ok : AD : : :
45: 1 : : -2: 1: 729: 15:Yes :Error: Ok : AD : : :
31: 0 : : -2: 0: 745: 12:Yes :Error: Ok : AD : : :
31: 1 : : -2: 1: 745: 12:Yes :Error: Ok : AD : : :
35: 0 : : -2: 0: 765: 47:Yes :Error: Ok : AD : : :
35: 1 : : -2: 1: 765: 47:Yes :Error: Ok : AD : : :
39: 0 : : -2: 0: 820: 5:Yes :Error: Ok : AD : : :
39: 1 : : -2: 1: 820: 5:Yes :Error: Ok : AD : : :
3D: 0 : : -2: 0: 828: 5:Yes :Error: Ok : AD : : :
3D: 1 : : -2: 1: 828: 5:Yes :Error: Ok : AD : : :
4F: 0 : : -2: 0: 834: 15:Yes :Error: Ok : AD : : :
4F: 1 : : -2: 1: 834: 15:Yes :Error: Ok : AD : : :
C3: 0 : : -1: 0: 115: 96:Yes : Ok : Ok : F3 : : :
C3: 1 : : -1: 1: 115: 96:Yes : Ok : Ok : F3 : : :
FA: 0 : Dr : -1: 0: 211: 73:Yes : Ok : Ok : 4E : : :Selfscan test microprogram
FA: 1 : Dr : -1: 1: 211: 73:Yes : Ok : Ok : 4E : : :Selfscan test microprogram
FF: 0 : Dr : -6: 0: 0: 705:Yes : Ok : Ok : FA : : :Selfscan module
FF: 1 : Dr : -6: 1: 0: 705:Yes : Ok : Ok : FA : : :Selfscan module
D4: 0 : Dr : -1: 0: 284: 464:Yes : Ok : Ok : 1C : : :Selfscan test microprogram
D4: 1 : Dr : -1: 1: 284: 464:Yes : Ok : Ok : 1C : : :Selfscan test microprogram
D5: 0 : Dr : -7: 0: 0: 464:Yes : Ok : Ok : 1B : : :Selfscan test microprogram
D5: 1 : Dr : -7: 1: 0: 464:Yes : Ok : Ok : 1B : : :Selfscan test microprogram
D6: 0 : Dr : -8: 0: 332: 464:Yes : Ok : Ok : 1A : : :Selfscan test microprogram
D6: 1 : Dr : -8: 1: 332: 464:Yes : Ok : Ok : 1A : : :Selfscan test microprogram
E9: 0 : Dr : -1: 0: 748: 94:Yes : Ok : Ok : 31 : : :Selfscan test microprogram
E9: 1 : Dr : -1: 1: 748: 94:Yes : Ok : Ok : 31 : : :Selfscan test microprogram
C4: 0 : Dr : -3: 0: 643: 90:Yes : Ok : Ok : 6F : : :Calibrations module
C4: 1 : Dr : -3: 1: 643: 90:Yes : Ok : Ok : 6F : : :Calibrations module
DA: 0 : Dr : -3: 0: 733: 80:Yes : Ok : Ok : DA : : :Selfscan test microprogram
DA: 1 : Dr : -3: 1: 733: 80:Yes : Ok : Ok : DA : : :Selfscan test microprogram
DB: 0 : Dr : -6: 0: 705: 80:Yes : Ok : Ok : E6 : : :Selfscan test microprogram
DB: 1 : Dr : -6: 1: 705: 80:Yes : Ok : Ok : E6 : : :Selfscan test microprogram
F4: 0 : Dr : -6: 0: 785: 80:Yes : Ok : Ok : EB : : :Selfscan test microprogram
F4: 1 : Dr : -6: 1: 785: 80:Yes : Ok : Ok : EB : : :Selfscan test microprogram
E5: 0 : Dr : -7: 0: 464: 80:Yes : Ok : Ok : A6 : : :Selfscan test microprogram
E5: 1 : Dr : -7: 1: 464: 80:Yes : Ok : Ok : A6 : : :Selfscan test microprogram
F5: 0 : Dr : -7: 0: 544: 75:Yes : Ok : Ok : D1 : : :Selfscan test microprogram
F5: 1 : Dr : -7: 1: 544: 75:Yes : Ok : Ok : D1 : : :Selfscan test microprogram
EF: 0 : Dr : -7: 0: 619: 73:Yes : Ok : Ok : D8 : : :Selfscan test microprogram
EF: 1 : Dr : -7: 1: 619: 73:Yes : Ok : Ok : D8 : : :Selfscan test microprogram
ED: 0 : Dr : -7: 0: 692: 63:Yes : Ok : Ok : 8A : : :Selfscan test microprogram
ED: 1 : Dr : -7: 1: 692: 63:Yes : Ok : Ok : 8A : : :Selfscan test microprogram
E4: 0 : Dr : -7: 0: 755: 51:Yes : Ok : Ok : B6 : : :Selfscan test microprogram
E4: 1 : Dr : -7: 1: 755: 51:Yes : Ok : Ok : B6 : : :Selfscan test microprogram
E3: 0 : Dr : -7: 0: 806: 56:Yes : Ok : Ok : A8 : : :Selfscan test microprogram
E3: 1 : Dr : -7: 1: 806: 56:Yes : Ok : Ok : A8 : : :Selfscan test microprogram
F3: 0 : Dr : -8: 0: 0: 54:Yes : Ok : Ok : 31 : : :Selfscan test microprogram
F3: 1 : Dr : -8: 1: 0: 54:Yes : Ok : Ok : 31 : : :Selfscan test microprogram
E7: 0 : Dr : -8: 0: 54: 54:Yes : Ok : Ok : 1B : : :Selfscan test microprogram
E7: 1 : Dr : -8: 1: 54: 54:Yes : Ok : Ok : 1B : : :Selfscan test microprogram
D7: 0 : Dr : -8: 0: 108: 55:Yes : Ok : Ok : F9 : : :Selfscan test microprogram
D7: 1 : Dr : -8: 1: 108: 55:Yes : Ok : Ok : F9 : : :Selfscan test microprogram
D8: 0 : Dr : -8: 0: 163: 50:Yes : Ok : Ok : 63 : : :Selfscan test microprogram
D8: 1 : Dr : -8: 1: 163: 50:Yes : Ok : Ok : 63 : : :Selfscan test microprogram
D2: 0 : Dr : -8: 0: 213: 50:Yes : Ok : Ok : 24 : : :Selfscan test microprogram
D2: 1 : Dr : -8: 1: 213: 50:Yes : Ok : Ok : 24 : : :Selfscan test microprogram
FD: 0 : Dr : -1: 0: 842: 5:Yes : Ok : Ok : 26 : : :Selfscan log
FD: 1 : Dr : -1: 1: 842: 5:Yes : Ok : Ok : 26 : : :Selfscan log
C5: 0 : Dr : -1: 0: 847: 3:Yes : Ok : Ok : 59 : : :Calibrations log (DCM)
C5: 1 : Dr : -1: 1: 847: 3:Yes : Ok : Ok : 59 : : :Calibrations log (DCM)
DC: 0 : Dr : -1: 0: 850: 1:Yes : Ok : Ok : 68 : : :Selfscan test microprogram
DC: 1 : Dr : -1: 1: 850: 1:Yes : Ok : Ok : 68 : : :Selfscan test microprogram
C6: 0 : : -1: 0: 851: 1:Yes : Ok : Ok : 59 : : :
C6: 1 : : -1: 1: 851: 1:Yes : Ok : Ok : 59 : : :
C9: 0 : : -1: 0: 852: 1:Yes : Ok : Ok : 36 : : :
C9: 1 : : -1: 1: 852: 1:Yes : Ok : Ok : 36 : : :
CD: 0 : : -1: 0: 853: 6:Yes : Ok : Ok : 1A : : :
CD: 1 : : -1: 1: 853: 6:Yes : Ok : Ok : 1A : : :
CF: 0 : : -1: 0: 859: 6:Yes : Ok : Ok : 0A : : :
CF: 1 : : -1: 1: 859: 6:Yes : Ok : Ok : 0A : : :
CB: 0 : : -1: 0: 865: 6:Yes : Ok : Ok : 0D : : :
CB: 1 : : -1: 1: 865: 6:Yes : Ok : Ok : 0D : : :
CC: 0 : : -2: 0: 850: 6:Yes :Error: Ok : AD : : :
CC: 1 : : -2: 1: 850: 6:Yes :Error: Ok : AD : : :
CA: 0 : : -2: 0: 856: 6:Yes :Error: Ok : AD : : :
CA: 1 : : -2: 1: 856: 6:Yes :Error: Ok : AD : : :
CE: 0 : : -2: 0: 862: 6:Yes : Ok : Ok : 11 : : :
CE: 1 : : -2: 1: 862: 6:Yes : Ok : Ok : 11 : : :
Number of zones......................... : 21
NN :Beg.cyl : End cyl : SPT0 : SPT1 : SPT2 : SPT3 : SPT4 : SPT5
1 :-32 : -1 : 900 : 900 : 900 : 900 : 900 : 900
2 :0 : 6239 : 1105 : 1105 : 1105 : 1105 : 1105 : 1105
3 :6240 : 12703 : 1080 : 1080 : 1080 : 1080 : 1080 : 1080
4 :12704 : 19135 : 1080 : 1080 : 1080 : 1080 : 1080 : 1080
5 :19136 : 26719 : 1044 : 1044 : 1044 : 1044 : 1044 : 1044
6 :26720 : 29695 : 1035 : 1035 : 1035 : 1035 : 1035 : 1035
7 :29696 : 34591 : 1012 : 1012 : 1012 : 1012 : 1012 : 1012
8 :34592 : 41215 : 990 : 990 : 990 : 990 : 990 : 990
9 :41216 : 47743 : 960 : 960 : 960 : 960 : 960 : 960
10 :47744 : 52287 : 936 : 936 : 936 : 936 : 936 : 936
11 :52288 : 53887 : 925 : 925 : 925 : 925 : 925 : 925
12 :53888 : 59615 : 900 : 900 : 900 : 900 : 900 : 900
13 :59616 : 62431 : 864 : 864 : 864 : 864 : 864 : 864
14 :62432 : 65695 : 840 : 840 : 840 : 840 : 840 : 840
15 :65696 : 69439 : 810 : 810 : 810 : 810 : 810 : 810
16 :69440 : 72607 : 780 : 780 : 780 : 780 : 780 : 780
17 :72608 : 75423 : 750 : 750 : 750 : 750 : 750 : 750
18 :75424 : 77983 : 720 : 720 : 720 : 720 : 720 : 720
19 :77984 : 80543 : 720 : 720 : 720 : 720 : 720 : 720
20 :80544 : 84479 : 675 : 675 : 675 : 675 : 675 : 675
21 :84480 : 87921 : 648 : 648 : 648 : 648 : 648 : 648
MODULES TABLE
SA Copy num Location Status
0 c: -3 H: 0 Ok
1 c: -3 H: 1 Ok
Number of modules....................... : 99
CONFIGURATION SECTOR (42)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
HDD ID
Model................................... : WDC WD2500JD-55HBB0
Serial number........................... : WD-WCAL73265957
Logical parameters...................... : LBA : 488 397 168
Master-password
Set..................................... : Yes
Text.................................... : WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD
Hex..................................... : 5744 4357 4443 5744 4357 4443 5744 4357 4443 5744 4357 4443 5744 4357 4443 5744
User-password
Set..................................... : No
Security level.......................... : High
Log DCM (C5)
0 c: -1 H: 0 Ok
1 c: -1 H: 1 Ok
Eagle TRL w EIC EGL 4E
+ EGL codata P.0A ----- Drive Head DCM Codes -----+
| old WDB/RR (zero-offset head) : F |
| HEADWAY (zero-offset head) : D |
| ALPS (zero-offset head) : A |
|new WDB/HBMT (zero-offset head) : M, U |
Avalable scripts
"Z" - Z9EGLP.0A
"_" - _9EGLP.0A
"V" - V9EGLP.0A
"T" - T9EGLP.0A
"W" - W9EGLP.0A
P-List (43)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
Number of defects....................... : 0
G-List (44)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
Defectoscope produces only ERROR's
Defectoscope (pass one) has been started
ERROR! LBA : 0 Verification error 48-bit (AMN) (51/01)
ERROR! LBA : 255 Verification error 48-bit (AMN) (51/01)
ERROR! LBA : 510 Verification error 48-bit (AMN) (51/01)
ERROR! LBA : 765 Verification error 48-bit (AMN) (51/01)
Defectoscope (pass one) has been interrupted
... and so on.
What i have overloocked?
Thanks for any help
Bruno
HD become ready:
Techno mode key:
Service area:
next the Head test:
Heads test
SA Structure Test:
MODULES TABLE
0 c: -3 H: 0 Ok
1 c: -3 H: 1 Ok
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
HDD ID
Master-password
User-password
Log DCM (C5)
0 c: -1 H: 0 Ok
1 c: -1 H: 1 Ok
Avalable scripts
"Z" - Z9EGLP.0A
"_" - _9EGLP.0A
"V" - V9EGLP.0A
"T" - T9EGLP.0A
"W" - W9EGLP.0A
P-List (43)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
G-List (44)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
... and so on.
Thanks for any help
Bruno
P-List (43)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
G-List (44)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
I can see it is Zero Defect... seem impossible....
if have original backup or track module... maybe u can write it back and perform trans regen..... if translator have been change. it is hard to recover data
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
G-List (44)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
Dear Steven
I could not be saved all modules, any are corrupt. e.G. 42, 43, 44, 59.
But i have 20, 23, 25, 4c and 4d and write it back.
I think, with defectoscope dhe defects could be found and writen i the defect list?
i mean for the whole SA track....
