WD1600AAJS
ZeBong
WD1600AAJS
Postby ZeBong » 23.02.09, 16:47
Hi to all,
Have this disk that dive this error in udma, when i gove power gets BSY them give error.
i try hotswap with a similiar drive, and i can test heads OK.
If i connect just the PCB also the same error.
ZeBong
ZeBong
Re: WD1600AAJS
Postby ZeBong » 25.02.09, 14:12
The picture off PCB is this:
Can anyone help-me on the PCB wich should be the problem.
ZeBong
Re: WD1600AAJS
Postby AJ2008 » 25.02.09, 14:18
Does disk reach DRD and DSC with donor PCB?
ZeBong
Re: WD1600AAJS
Postby ZeBong » 25.02.09, 14:31
Hi AJ2008,
yes with other PCB the drive get DRD DSC.
it's not 100% compatible because the model is the same wd1600aajs-xxxxxx ( this are different)
i try a hotswap, and i can test heads 100% ok.
So i think the problem is in the PCB, but i can not find it anyhere the disk also is from 17 JUN 2008.
ZeBong
Re: WD1600AAJS
Postby AJ2008 » 25.02.09, 14:33
Have you used a multimeter to test the readings of components at top right of PCB?
Also what is full model of WD drive?
ZeBong
Re: WD1600AAJS
Postby ZeBong » 25.02.09, 14:42
no not yet, can you show-me wich component shoul i read from multimiter.
the full model is:
WD1600AAJS-00B4A0
MALAYSIA
17 JUN 2008
DCM: HGNNNT2CG
Re: WD1600AAJS
Postby AJ2008 » 25.02.09, 14:46
I believe that is a Marvel WD from pinnacle family. I am not sure if this is ROYL, if it is then you can perform ROM restoration via PC3K.
If you have working donor PCB, use your multimeter to test components on both PCBs and verify differences in reading.
ZeBong
Re: WD1600AAJS
Postby ZeBong » 25.02.09, 20:25
Hi AJ2008,
ZeBong
Re: WD1600AAJS
Postby ZeBong » 26.02.09, 14:45
Hi to all,
Afther all is not PCB problem, i try other ROM from Sa from other model and the error in the ATA register is gone, i can have the drive ready, but dont have the ID.
need FW for this disk :
WD1600AAJS-00B4A0
MALAYSIA
17 JUN 2008
DCM: HGNNNT2CG
Can Anyone see if have this to share with me.
Jose
ZeBong
Re: WD1600AAJS
Postby ZeBong » 26.02.09, 19:53
I try to Make a ROM recovery
Happen this :
Then came back to the beggining:
Now the drive when i connect it it give always ATA Erros: ERR ABR
Can not run the utility.
Put the disk in Kernel Mode, and make a ROM Restoration
Them give a error.
When i power off power on the disk get DRD DSC and i can run it again with the utility but i can not have any ID.
What should i do next ?
Jose
ZeBong
Re: WD1600AAJS
Postby ZeBong » 27.02.09, 13:12
When i gove power i have this:
Enter the utility
Techno mode key
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : 1311
ROM version............................. : 01.0CA
ROM generation.......................... : 01.0CA
Link table version...................... : 03.0A.
Heads number in use..................... : 1
Head map................................ : 0
Firmware version........................ : 0001000C
Service area:
SA dir reading.......................... : Ok
Configuration reading................... : No SA copy avalabled
