toshiba info
compuman
toshiba info
Postby compuman » 23.02.09, 11:40
hi to every one
could someone please tell me how shall i connect the usb terminal on a sata toshiba because i am gettins some errors! or if there are some updates which i have to install them?
dmarques
Re: toshiba info
Postby dmarques » 25.02.09, 09:46
Why do you need to connect the usb terminal to Toshiba drive?
Alberto
Re: toshiba info
Postby Alberto » 03.03.09, 16:55
toshiba doesnt has terminal log from startup like Seagate until im know
steven
Re: toshiba info
Postby steven » 25.03.09, 10:45
there is a terminal access for Toshiba. But it is not so important
tec
Re: toshiba info
Postby tec » 10.08.10, 14:00
Please supply terminal connection layout for Toshba SATA drives.
ddr
Re: toshiba info
Postby ddr » 13.08.10, 07:56
I also require the toshiba SATA terminal connection layout. You do need to connect terminal to allow capture of the CP modules?
Joel
ddr
Re: toshiba info
Postby ddr » 13.08.10, 08:08
Found a diagram on another forum.. Worked well..
tec
Re: toshiba info
Postby tec » 13.08.10, 14:02
Thank you :-)
gterry
Re: toshiba info
Postby gterry » 07.06.12, 16:53
Is the ground pin required? On the deepspar forum they only show the txd/rxd connected.
Re: toshiba info
Postby AJ2008 » 07.06.12, 18:04
You need only TX and RX attached to the middle jumper pins.
At terminal window hit "Enter" you should see a ">" sign if terminal is correctly attached.
IF not, switch positions of TX + RX connections.
gterry
Re: toshiba info
Postby gterry » 07.06.12, 19:02
Thanks!!
Return to “Toshiba native”
