change ATA 0 to ATA 1 when job is started
manel
Postby manel » 05.02.09, 09:33
Hi!
I've a doubt. I started to clone one disk (ATA 0 TO USB) to other, but I stoped because I need to plug in on ATA 0 other disk to do some experiments. (ATA 1 was working). Then I leave the disk doing "experiments" on ATA 0 and now ATA 1 is finished. It's possible to "modify" the JOB remaining to continue the scanning instead of ATA 0, ATA 1 (Same destination -> USB)
Thx !!!
Pepe
Re: change ATA 0 to ATA 1 when job is started
Postby Pepe » 05.02.09, 23:57
Create a new task with the new setup, then close it and copy map.bin from the old folder to the new one and launch the new task again.
then set the starting LBA somewhere near before the last scan ended and start cloning
pepe
manel
Postby manel » 06.02.09, 11:14
Pepe wrote:Create a new task with the new setup, then close it and copy map.bin from the old folder to the new one and launch the new task again.
pepe
I love you. I think I should send you chocolat or flowers :mrgreen: :mrgreen:
so pleasured!!!
TTHX
Postby AJ2008 » 13.02.09, 10:56
You also need to copy all files from the folder except the task.prm and task.bak files to the new folder, this will transfer all the imaged data so far, if at all anything has already been imaged.
Pepe
Postby Pepe » 13.02.09, 17:34
yes, the FDB contains info about the folder structure in the 'explorer' view.
He was imaging to USB, so there should not be any image files, but U are correct, thanx
pepe
Return to “Data Extractor”
