WD5000AAJB
ZeBong
WD5000AAJB
Postby ZeBong » 30.01.09, 19:33
Need help about this disk WD5000AAJB
have the PCB Burn, its burned microprocessor and doesnt has external ROM :(
ZeBong
Re: WD5000AAJB
Postby ACE_Admin » 03.02.09, 13:30
Tell me please full model of this drive , like WD5000AAJB-xxYYxx
Also do you have same family donor for this drive ?
For this drive you should find a compartible pcb with same symbols in the middle of the second part of the model and swap the pcb.
Then make a SA Structure test and provide us a report.
ZeBong
Re: WD5000AAJB
Postby ZeBong » 03.02.09, 16:17
The full model is : WD5000AAJB-00YRA0
Will try to find a donor.
ZeBong
Igor
Re: WD5000AAJB
Postby Igor » 04.02.09, 09:20
Dear ZeBong,
1. You should find a compatible WD donor drive and resources for Tornado 2R family.
2. Swap the PCB and run ROM restoration method.
Regards.
Overflo
Re: WD5000AAJB
Postby Overflo » 05.03.09, 14:16
I had a similar problem.
the model that failed is: WD5000AAJS-32YFA0
the donor is: WD5000AAJS-22TKA0
it is impossible to find the same harddrive anywhere :(
the resource master creation in DB did work 100%
then i restarted the tool in kernel mode and go to:
Tests->Work with ROM -> ROM recovery
the wizards starts.
then i choose the right model resource i imported from Tornado2R.pcr.
then ic click the button ">>"
then i get a popup stating "Fatal error" and the wizard is closing.
no matter which version i choose from the list it always dies with "Fatal error".
any hints?
Re: WD5000AAJB
Postby AJ2008 » 06.03.09, 10:08
What determines compatibility for donor to use ROM restoration?
