WD1600
ZeBong
WD1600
Postby ZeBong » 29.01.09, 12:28
Hi Have this disk that the heads where stuck in the platte.
Remove the head to the park zone.
I could detect the disk and the DRD / DSC
Save the resources disk to the database
I start copy data in reverse.
But now the disk is not detect anymore.
When i start the utility it give-me two RED errors.
Code: Select all
Techno mode key
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "SERVO ERROR CODE BASE SvirLatchHang"
ROM version............................. : 09.9NF
ROM generation.......................... : 09.9NF
Link table version...................... : 03.8E.
Head map................................ : 0,1,2,3
Firmware version........................ : 0009009N
Service area:
SA dir reading.......................... : Unknown error. Code(0)
What should i do next.
ZeBong
Re: WD1600
Postby ZeBong » 29.01.09, 19:08
Open Again the disk in the clean room, and give power to it.
I Notice that the disk try to read the SA ok, wait some time and read it and detect it in the PC.
Next
I connect to the pc3kudma , and i am getting the data again. :)
ZeBong
Re: WD1600
Postby ZeBong » 30.01.09, 19:35
Have make the disk 100% :)
Pepe
Re: WD1600
Postby Pepe » 03.02.09, 01:21
good news :)
pepe
