Dear all
I have a Seagate Drive, that sounds normal recalibration, but the BSY signal is allways on.
The 7200.11 on the PC-3000UDMA dont exist. I tested all Seagate types.
Output, when i test the 7200.10 Bugfix: Terminal : error detecting HDD terminal baud rate
What can i doo??
I should recover the data
Very thanks
Bruno
ST37506360AS bARRACUDA 7200.11
Re: ST37506360AS bARRACUDA 7200.11
You need updated version of PC3000 (4.13 I think), and under the Seagate section, there is a sub-section called F3 Architecture. Within this there is a single button allowing repair of these seagates.
If you do not have F3 architecture, and have paid for tech support, you need to contact acelab.
Have you tech support contracted?
Yes i have tech support contacted. We solve the update problem.
I hope, very fast....
Thanks vor Answers
Bruno
Thanks vor Answers
Bruno
