Dears,
I am with problem in this HDD - where I do not obtain to have access module 02.
This is the error that it shows:
Techno mode key
Cyl Count............................... : 83935
SA SPT.................................. : 533
ROM Data size........................... : 128 Kb
Head Map Reading Error.................. : Module 0A reading error Data request error Techno CMD sending error Device Error Detected: "VSCE DRIVE PROTECT LOCKED"
ROM version............................. : 10.9KE
ROM generation.......................... : 10.9KE
Link table version...................... : 02.8D.
Heads number............................ : 0
Heads number in use..................... : 0
Firmware version........................ : Module 0D reading error Data request error Techno CMD sending error Device Error Detected: "VSCE DRIVE PROTECT LOCKED"
Service area:
SA dir reading.......................... : Device error detected
WD800JD-75MSA3 - Error Module 02 - VSCE DRIVE PROTECT LOCKED
- Alexandre Silveira
Re: WD800JD-75MSA3 - Error Module 02 - VSCE DRIVE PROTECT LOCKED
Dears,
If execute the procedure of HOT SWAP method that the area of data of the HDD with defect is possible to get access.
Alexandre Silveira
Alexandre Silveira
Of course No, because this problem is not with Service Area. There is problem with ROM your HDD. Can you see the following lines:
It means that the whole ROM is reading OK, but when you try to read the modules of ROM then it makes error. That is why the problem is in microprogram. I think so.
You should take all modules from DUMP of whole ROM. For that try to cut it with use HEX editor and put into new ROM. Don't forget to recalculate check summ every modules.
Best regards, Vadim Morozov
ACE Laboratory technical director
