HDD Momentus ST9120822AS
CarlosAdolfo
Postby CarlosAdolfo » 13.01.09, 20:57
I have a HDD Momentus 5400.3, 120 GB, Model ST9120822AS, FW 3.CAE.
PC-3000 UDMA does not recognize it. By via terminal it gives the following errors.
Selected family......................... : Momentus (Venus)
Selected model.......................... : ST9120822AS
Model by ID............................. : <HDD ID NOT READ>
Detection of HDD COM port baud rate..... : 9600
HM HM REG701 88
HM REG701 88
HM REG701 88
HM REG701 88
HM
F>Pgm=00 Trk=0000F019(0000F019[000000]).0(0).1A4(1A4) Zn=FF Err=A2 ErCt=0000 Hlth=0000 CHlth=0000 Ntrdy LBA=00000000
F>
Age=00 Type=00 MxCyl=0000F123 MxHd=00 MxSct=277 BSz=008M TCode=00000000
F>
Cmd Cyl Hd Sct Cnt Stbuf Segl Csct Cbuf Actv ErCd RWOp Rd Wr RWOp1 Flags
10 00000000 00 0000 0000 0000 0000 01A4 0000 N A2 FFFF.FF.80.0000 1800
F>
e c r = 0 0 1
e c r = 0 1 0
Command Inactive - No VALID Cert Code Detected
F>
cmd 04, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
Reset
4096k x 16 DRAM
VENUS - 1_Disk S-0C 12-01-06_14:56
cmd 1A, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
Buzz
cmd 10, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
HM REG701 88
HM REG701 88
HM REG701 88
HM REG701 88
HM REG701 88
HM REG701 88
HM REG701 88
HM REG701 88
What I can do in this case.
CarlosAdolfo
Pepe
Re: HDD Momentus ST9120822AS
Postby Pepe » 15.01.09, 01:37
probably nothing.
This drive is from a MacBook, probably overheated. The heads are damaged and probably the platters too.
I did some MHA replacements but none worked. The donor heads did not get damaged due to limiting their movement to avoid the scratched area, they work quite well after putting them back into their HDA.
But even the SA could not be read, so I persume there is some media degradation problem.
pepe
Igor
Postby Igor » 15.01.09, 08:45
Dear CarlosAdolfo,
At this case you should check the power of commutator or if it wouldn't help you can do a Head Swap. HM errors always mean that you've got problems with PCB or Heads. Sometimes them both can be damaged.
Regards.
CarlosAdolfo
Postby CarlosAdolfo » 15.01.09, 13:57
As he says PEPE is a disc with the APPLE logo.
HDD ST9120822AS FW 3.CAE (APPLE logo)
Donor ST9120822AS FW 3.AXC (without APPLE logo)
I can Make HEAD and PCB the swap?
Recommendations to make the swap
CarlosAdolfo
Pepe
Postby Pepe » 16.01.09, 02:29
U can try the head swap, but be prepared to severe platter damage near the inner perimeter of the platters. As it is a 120G drive having 3 heads, the upper head is missing and U won't see any damage on the top side.
But as u take out the MHA U will have to examine the heads under a microscope or a good magnifier to check if they are dirty.
They will be dirty 98% :(
then U can decide to try the swap or not. if yes, make sure that the new MHA won't touch the damaged area of the platters.
But as I told U I had no luck with them, replaced the heads which remained functional in the donor after swapping back, but they were unable to read anything from the patient surface (apart from the boot adapts and reserved track defect list - 5 sectors )
regards,
pepe
