D400BD75MRA2 - VSCE drive protect locked
tec
Postby tec » 13.01.09, 10:40
Hi there, Any idea on how to resolve/remove/open a "VSCE drive protect locked" situation from a WD400BD.
Alexandre Silveira
Re: D400BD75MRA2 - VSCE drive protect locked
Postby Alexandre Silveira » 14.01.09, 15:20
Which is the version of your PC3000 ?
Alexandre Silveira
tec
Postby tec » 14.01.09, 16:18
Hi there Alexandre, Version 4042491
Alexandre Silveira
Postby Alexandre Silveira » 15.01.09, 12:09
* If you want datarecovery you will be able to execute the procedure of HOT SWAP method that the area of data of the HDD with defect is possible to get access.
Alexandre Silveira
tec
Postby tec » 15.01.09, 13:59
Thank you Alexandre
tec
Postby tec » 16.01.09, 13:27
The solution for this drive in removing the VSCE drive protect locked is to overwrite module 02 - Configuration (HDD ID) :D
