SAMSUNG HM120JC
ZeBong
SAMSUNG HM120JC
Postby ZeBong » 06.01.09, 23:54
Have a Samsung case that the head where stuck in the platte, when i remove it very slow to the park zone, and turn on the disk, i get the ID DRD/DSC, and i could start copy some sectors green with DE.
Afther a while, it start to give error.
i Stop the disk them see the terminal and appear this:
IndS=+00005
Spn OK
H: +00000
Load
UF: 1st Gray err
H: +00001
Load
UF: 1st Gray err
H: +00002
Load
UF: 1st Gray err
H: +00003
Load
UF: 1st Gray err
Unload 0002
H: +00000
Load
UF: 1st Gray err
Unload 0002
H: +00001
Load
UF: 1st Gray err
Unload 0002
H: +00002
Load
SK C: 000080AF
C: 000001F4 H: +00000
SR : +00000
UF: 1st Sk err
H: +00001
SK C: 000012D9
AP_EST
SR : +00001
UF: 1st Sk err
H: +00001
SK C: 000003E1
SR : +00002
Unload 0001
H: +00000
Load
UF: 1st Gray err
H: +00001
Load
UF: 1st Gray err
H: +00002
Load
UF: 1st Gray err
H: +00003
Load
UF: 1st Gray err
Unload 0002
H: +00000
Load
UF: 1st Gray err
Unload 0002
H: +00001
Load
UF: 1st Gray err
Unload 0002
H: +00002
Load
SK C: 00008731
AP_EST
SR : +00003
UF: 1st Sk err
H: +00001
SK C: 000007C7
LED 13
LED 13
In the manual says:
0x13 - Head Unlatch error
It looks like head problem, the question is if i change heads will they work ok?
ZeBong
Pepe
Re: SAMSUNG HM120JC
Postby Pepe » 07.01.09, 02:38
in most of the cases this relates to head/preamp problem, most likely head.
pepe
Re: SAMSUNG HM120JC
Postby AJ2008 » 07.01.09, 10:20
I agree with pepe. Heads were parked incorrectly on media, I assume client had powered many times before sending to a pro, and head has sustained damage.
replace heads
