I have UDMA PC3000 ver 4.12, and DE version 4.04. Up until this update, I have been able to use the HEAD MAP feature within DE during a data copy. Now, I simply get the message 'You Must Build The Heads Map'.
What exactly does this mean? Is there something I am missing?
Head Map
Re: Head Map
Hi AJ 2008
On Dataextractor, klick "Service" and then go down to menupoint "Building heads map" and klick them. On next Window click ok. Thats it. The DataExtractor is now Nuilding the Headmap.
After that is done. You can work like prior version of DE.
good luck
Bruno
good luck
Bruno
Re: Head Map
Hi Bruno,
That works perfect, thanks. I cant believe I overlooked it!!
Anyway, I appreciate it.
Regards,
Regards,
