ST91608220AS
Hander
ST91608220AS
Postby Hander » 15.12.08, 20:49
I have an ST91608220AS hybrid drive with the following log:
Code: Select all
Reset
4096k x 16 DRAM
LARAMIE - 1_Disk    S-1F   07-09-07_13:15
Buzz HM SFI
(P)
.FSTOP(0, 2400).FA_State(0).FA_CNT(1)
LBA(FFFFFE77).LEC(0).X(8).PG(147F8),SABNR(78).VBM(3C98).SAVH(78,78).HVBM(3C80),L
VBM(3C80).ERROUT
TblRdErr
NVC:Reconstructing
LBA(FFFFFE77).LEC(0).X(8).PG(147F8),SABNR(F9).VBM(3C98).SAVH(F9,F9).HVBM(3BFF),L
VBM(3BFF).ERROUT
TblRdErr
I suspect it is having some problems with the onboard flash memory, but I don't have any solution yet.
Do you have any info about it?
thx,
Hander
Pepe
Re: ST91608220AS
Postby Pepe » 27.12.08, 13:35
Problem solved in the meantime.
thanx for reading.
pepe (Hander)
ZeBong
Re: ST91608220AS
Postby ZeBong » 27.12.08, 19:47
Hi, how did you solve the problem i had one with the same log in terminal.
Can you share it, with us.
ZeBong
Re: ST91608220AS
Postby AJ2008 » 05.01.09, 18:36
I would like to know of the solution also.
