search firmware for a fujitsu MAW3073NC
avenger-fr
Postby avenger-fr » 20.11.08, 18:19
Hi !
I search all modules for a fujitsu MAW3073NC (firmware version 2904)
(or if you can't upload all ... just number 09/0D/0E/2E/7B/82/83/84/85/E0)
Thanks !
avenger-fr
Re: search firmware for a fujitsu MAW3073NC
Postby avenger-fr » 01.12.08, 17:22
Hi !
Finnaly I have found a other drive Fujitsu MAW who works well (it's have only a firmware marked bad : TO).
I have try to repair all bad firmwares with it but the module LOG write well and read bad after an off/on, and the drive is always recognized in 48Mb. I have validate the two head with the function Service Information Object : tracks. I can read some user data on some tracks (on the two head) with this function, but without the Plist...
I have already try the hotswap but without success.
I don't know what I must do...
Anybody can help me ???
Thanks !
All the logs :
    SA structure test
    Heads map............................... : OK
    Reading modules...
    DM...................................... : OK
    GL...................................... : OK
    DT...................................... : OK
    DI...................................... : OK
    PG...................................... : OK
    SCYL.................................... : OK
    MS...................................... : OK
    RI...................................... : OK
    DI2..................................... : OK
    SKIP.................................... : OK
    DRVP.................................... : OK
    LOG..................................... : ASPI Command exec error - Read module error (Id: D)
    TO...................................... : ASPI Command exec error - Read module error (Id: E)
    HDA..................................... : OK
    SCHD.................................... : OK
    SDTP.................................... : OK
    JUDG.................................... : OK
    ERKD.................................... : OK
    SMDT.................................... : OK
    SQDT.................................... : OK
    ENDL.................................... : OK
    DEF0.................................... : OK
    DEF1.................................... : OK
    CORM.................................... : OK
    TPIM.................................... : OK
    VMMM.................................... : OK
    OFSM.................................... : OK
    PL...................................... : OK
    PRSV.................................... : OK
    TS...................................... : OK
    CS...................................... : OK
    FSKW.................................... : OK
    SASL.................................... : OK
    ICYL.................................... : OK
    ZONE.................................... : OK
    MR...................................... : OK
    SCRT.................................... : OK
    EV01.................................... : OK
    APPL.................................... : OK
    STL..................................... : OK
    LOG2.................................... : OK
    ELG0.................................... : OK
    ELG1.................................... : OK
    ELG2.................................... : OK
    ELG3.................................... : OK
    ELG4.................................... : OK
    ELG5.................................... : OK
    ELG6.................................... : OK
    ELG7.................................... : OK
    ELG8.................................... : OK
    ELG9.................................... : OK
    ELGA.................................... : OK
    ELGB.................................... : OK
    ELGC.................................... : OK
    ELGD.................................... : OK
    ELGE.................................... : OK
    ELGF.................................... : OK
    POSQ.................................... : OK
    PSM0.................................... : OK
    PSM1.................................... : OK
    PSM2.................................... : OK
    PSEO.................................... : OK
    DI3..................................... : OK
    SSKW.................................... : OK
    DCST.................................... : OK
    SIDE.................................... : OK
    SCTR.................................... : OK
    CSSM.................................... : OK
    VGAM.................................... : OK
    ASYM.................................... : OK
    LOG0.................................... : OK
    LOG1.................................... : OK
    FA00.................................... : OK
    FA01.................................... : OK
    FA02.................................... : OK
    FA03.................................... : OK
    FA04.................................... : OK
    FA05.................................... : OK
    SVL0.................................... : OK
    SVL1.................................... : OK
    SVL2.................................... : OK
    SVL3.................................... : OK
    SVL4.................................... : OK
    SVL5.................................... : OK
    SVL6.................................... : OK
    SVL7.................................... : OK
    SVL8.................................... : OK
    SVL9.................................... : OK
    SVLA.................................... : OK
    SVLB.................................... : OK
    SVLC.................................... : OK
    SVLD.................................... : OK
    SVLE.................................... : OK
    SVLF.................................... : OK
    CS1..................................... : OK
    PLIST reading........................... : ASPI Command exec error - Read PList error
    GLIST reading........................... : ASPI Command exec error - Read module error (Id: 1)
    Duration................................ : 00:00:55
    HDD Self Test
    SCSI CDB Sent........................... : 1D 04 00 00 00 00
    SRB Status.............................. : 04 [SRB completed with error]
    Host Adapter Status..................... : 00 [Host adapter did not detect error]
    Target Status........................... : 02 [Check Condition]
    Sense Key............................... : 04 [Hardware Error]
    Additional Sense Code................... : 4C
    +Sense Code Qualifier................... : A7 []
    Fujitsu Vendor Specific (UEC)........... : Logical unit failed selfconfiguration. The IDD's initial setup failed. SA Read error (any 4/44/** error during SA read).
    Ok
    SA STRUCTURE
    SERVICE AREA PARAMETERS
    Zone #.................................. : 0
    Initial cylinder........................ : -4
    Final cylinder.......................... : -143
    SPT..................................... : 715
    Heads map............................... : 01 00
    ZONE ALLOCATION TABLE
    Number of zones......................... : 18
    # : Head : Initial cylinder : Final cylinder : SPT :
    1 : 0 : 0 : 4 256 : 1 185 :
    1 : 1 : 0 : 4 408 : 1 165 :
    2 : 0 : 4 257 : 8 541 : 1 165 :
    2 : 1 : 4 409 : 8 846 : 1 140 :
    3 : 0 : 8 542 : 12 854 : 1 140 :
    3 : 1 : 8 847 : 13 313 : 1 140 :
    4 : 0 : 12 855 : 17 195 : 1 140 :
    4 : 1 : 13 314 : 17 809 : 1 102 :
    5 : 0 : 17 196 : 21 564 : 1 094 :
    5 : 1 : 17 810 : 22 334 : 1 071 :
    6 : 0 : 21 565 : 25 961 : 1 064 :
    6 : 1 : 22 335 : 26 888 : 1 042 :
    7 : 0 : 25 962 : 30 386 : 1 026 :
    7 : 1 : 26 889 : 31 471 : 1 026 :
    8 : 0 : 30 387 : 34 867 : 997 :
    8 : 1 : 31 472 : 36 112 : 977 :
    9 : 0 : 34 868 : 39 348 : 957 :
    9 : 1 : 36 113 : 40 753 : 940 :
    10 : 0 : 39 349 : 43 857 : 929 :
    10 : 1 : 40 754 : 45 423 : 912 :
    11 : 0 : 43 858 : 48 366 : 912 :
    11 : 1 : 45 424 : 50 093 : 874 :
    12 : 0 : 48 367 : 52 875 : 855 :
    12 : 1 : 50 094 : 54 763 : 843 :
    13 : 0 : 52 876 : 57 356 : 820 :
    13 : 1 : 54 764 : 59 404 : 810 :
    14 : 0 : 57 357 : 61 725 : 798 :
    14 : 1 : 59 405 : 63 929 : 775 :
    15 : 0 : 61 726 : 65 870 : 749 :
    15 : 1 : 63 930 : 68 222 : 741 :
    16 : 0 : 65 871 : 69 875 : 716 :
    16 : 1 : 68 223 : 72 370 : 706 :
    17 : 0 : 69 876 : 73 768 : 684 :
    17 : 1 : 72 371 : 76 402 : 684 :
    18 : 0 : 73 769 : 73 770 : 655 :
    18 : 1 : 76 403 : 76 404 : 646 :
    MODULES TABLE
    : ID : Module : Length : Read : ChSum :
    : 00 : DM : 188 : OK : OK :
    : 01 : GL : 156 : OK : OK :
    : 02 : DT : 256 : OK : OK :
    : 03 : DI : 1 : OK : OK :
    : 04 : PG : 141 : OK : OK :
    : 05 : SCYL : 18 : OK : OK :
    : 06 : MS : 2 : OK : OK :
    : 08 : RI : 2 : OK : OK :
    : 09 : DI2 : 1 : OK : OK :
    : 0A : SKIP : 1 : OK : OK :
    : 0B : DRVP : 36 : OK : OK :
    : 0D : LOG : 85 : Err : -- :
    : 0E : TO : 12 : Err : -- :
    : 0F : HDA : 1 : OK : OK :
    : 10 : SCHD : 64 : OK : OK :
    : 11 : SDTP : 6 : OK : OK :
    : 12 : JUDG : 3 : OK : OK :
    : 13 : ERKD : 2 : OK : OK :
    : 14 : SMDT : 3 : OK : OK :
    : 15 : SQDT : 16 : OK : OK :
    : 16 : ENDL : 5 : OK : OK :
    : 17 : DEF0 : 256 : OK : OK :
    : 18 : DEF1 : 256 : OK : OK :
    : 19 : CORM : 8 : OK : OK :
    : 1A : TPIM : 60 : OK : OK :
    : 1B : VMMM : 60 : OK : OK :
    : 1C : OFSM : 60 : OK : OK :
    : 1D : PL : 188 : OK : OK :
    : 1E : PRSV : 5 : OK : OK :
    : 20 : TS : 21 : OK : OK :
    : 21 : CS : 12 : OK : OK :
    : 22 : FSKW : 3 : OK : OK :
    : 23 : SASL : 1 : OK : OK :
    : 24 : ICYL : 63 : OK : OK :
    : 25 : ZONE : 600 : OK : OK :
    : 28 : MR : 1 : OK : OK :
    : 2A : SCRT : 2 : OK : OK :
    : 2B : EV01 : 190 : OK : OK :
    : 2C : APPL : 34 : OK : OK :
    : 2D : STL : 1 : OK : OK :
    : 2E : LOG2 : 400 : OK : OK :
    : 30 : ELG0 : 200 : OK : OK :
    : 31 : ELG1 : 200 : OK : OK :
    : 32 : ELG2 : 200 : OK : OK :
    : 33 : ELG3 : 200 : OK : OK :
    : 34 : ELG4 : 200 : OK : OK :
    : 35 : ELG5 : 200 : OK : OK :
    : 36 : ELG6 : 200 : OK : OK :
    : 37 : ELG7 : 200 : OK : OK :
    : 38 : ELG8 : 200 : OK : OK :
    : 39 : ELG9 : 200 : OK : OK :
    : 3A : ELGA : 200 : OK : OK :
    : 3B : ELGB : 200 : OK : OK :
    : 3C : ELGC : 200 : OK : OK :
    : 3D : ELGD : 200 : OK : OK :
    : 3E : ELGE : 200 : OK : OK :
    : 3F : ELGF : 200 : OK : OK :
    : 52 : POSQ : 70 : OK : OK :
    : 53 : PSM0 : 256 : OK : OK :
    : 54 : PSM1 : 256 : OK : OK :
    : 55 : PSM2 : 256 : OK : OK :
    : 56 : PSEO : 256 : OK : OK :
    : 59 : DI3 : 1 : OK : OK :
    : 5A : SSKW : 58 : OK : OK :
    : 60 : DCST : 16 : OK : OK :
    : 61 : SIDE : 32 : OK : OK :
    : 62 : SCTR : 256 : OK : OK :
    : 63 : CSSM : 6 : OK : OK :
    : 65 : VGAM : 60 : OK : OK :
    : 66 : ASYM : 60 : OK : OK :
    : 7A : LOG0 : 400 : OK : OK :
    : 7B : LOG1 : 400 : OK : OK :
    : 80 : FA00 : 200 : OK : OK :
    : 81 : FA01 : 200 : OK : OK :
    : 82 : FA02 : 200 : OK : OK :
    : 83 : FA03 : 200 : OK : OK :
    : 84 : FA04 : 200 : OK : OK :
    : 85 : FA05 : 200 : OK : OK :
    : A0 : SVL0 : 256 : OK : OK :
    : A1 : SVL1 : 256 : OK : OK :
    : A2 : SVL2 : 256 : OK : OK :
    : A3 : SVL3 : 256 : OK : OK :
    : A4 : SVL4 : 256 : OK : OK :
    : A5 : SVL5 : 256 : OK : OK :
    : A6 : SVL6 : 256 : OK : OK :
    : A7 : SVL7 : 256 : OK : OK :
    : A8 : SVL8 : 256 : OK : OK :
    : A9 : SVL9 : 256 : OK : OK :
    : AA : SVLA : 256 : OK : OK :
    : AB : SVLB : 256 : OK : OK :
    : AC : SVLC : 256 : OK : OK :
    : AD : SVLD : 256 : OK : OK :
    : AE : SVLE : 256 : OK : OK :
    : AF : SVLF : 256 : OK : OK :
    : E0 : CS1 : 192 : OK : Err :
    PLIST - DEFECTIVE SECTORS LIST
    Number of defects : 0
    : NN : Cylinder : Head : Sector :
    GLIST - REASSIGNED SECTORS LIST
