Can anyone tell-me which family can i use to this disk : WD5000AAVS-00ZTB0
I have two disk off this model for datarecovery.
First One it detect all ID serial Model.
Second one dont detect anything. ( FOTO2 )
It gives DRD DSC, think PCB.
ZeBong
WD5000AAVS-00ZTB0
WD5000AAVS-00ZTB0
- Attachments
- WD5000AAVS.jpg (94.84 KiB) Viewed 5210 times
Re: WD5000AAVS-00ZTB0
Hello ZeBong,
This drive WD5000AAVS-00ZTB0 correspond to Spider family, but we do not support it. That is why you couldn't work with it.
Regards.
Regards.
Hello Igor,
Do you know when it will be supported ?
when i connect the the pc3kumda family pinnacle it gives this :
Techno mode key
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "SERVO ERROR CODE BASE SvirCalRRO Hd1"
ROM version............................. : 5C.3BG
ROM generation.......................... : 5C.3BG
Link table version...................... : 01.42.
Head map................................ : 0,1,2,3
Firmware version........................ : 005C003B
Service area:
SA dir reading.......................... : Unknown error. Code(0)
ZeBong
Techno mode key
Service area:
ZeBong
When will support for families such as Spider and Kermit be added?
Hi ZeBong.
I have here the same model and PC3000 gives me the same information. Did you manage the problem with the WD5000AAVS? My PC3000 support spider-models, but I can't find a way to fix the problems.
Best
MrHopper
Best
MrHopper
