Barracuda 7200.9 stays BSY
DR_Ireland
Postby DR_Ireland » 26.09.08, 14:11
Model: ST3500641AS
F/W: 2.AAA
DateCode: 06132
SiteCode: AMK
Drive spins up, makes one strong knock and stays busy.
Code: Select all
Terminal output:
              Spin Ready
Error Reading Application Code
F>j
Application code incompatible with serial flash code
    Code - 76  Track 15873.0.01E  Sns 01E
What to do now?
Thanks, Pawel.
Igor
Re: Barracuda 7200.9 stays BSY
Postby Igor » 30.09.08, 14:59
Hello DR_Ireland,
The problem in terminal indicate a problem with PCB.
This problem fully discribed in our Seagate manual.
9.7 The "Application code incompatible with serial flash code" message.
Regards.
rafaela
Postby rafaela » 02.11.08, 12:40
The heads have been misaligned u need to change heads or realign them , the heads have lost its Servo marker and therefore it need App code .
There is one more way to recover data from this error write app code to ram and start using Start (safe) in loader , goto data extractor and clone data .
ZeBong
Postby ZeBong » 05.11.08, 16:01
Hi Rafaela,
Can you explain in detail how to resolve this problem.
i have one similiar to this error.
ZeBong
