Hitachi Deskstar - no spin
Balvan
Postby Balvan » 03.09.08, 06:47
I've got a bad 400 GB Hitachi Deskstar that won't spin up. The motor ohms fine and the PCB is not the problem.
Before I open this bad boy up (10 heads / 5 platters) I would like to know if:
1. Bearing seizures are common on this model;
2. What kind of success people are having with head/platter transplants;
3. If the bearing can be loosened successfully without having to do step 2
Thx
dmarques
Postby dmarques » 03.09.08, 17:23
1. Bearings seizures are very commun on this models, not so much as Seagate.
But if you open the drive I'm sure in 1 sec you can determine if it's a spindle seizure.
