WD1200BEVS - Kernel mode how to
ZeBong
Postby ZeBong » 02.07.08, 23:45
hELLO,
How can i put in kernel mode a WD notebook SATA disk.
i connect directly to the sata cable and power cable with the adapator.
Jose
Postby ACE_Admin » 03.07.08, 13:08
tell me the full model of the drive.
and - you may try to unscrew the board from HDA , connect it to PC-3000, start wd utility , power on the drive with "Kernel mode" option selected.
Nikola Radovanovic
Re: WD1200BEVS - Kernel mode how to
Postby Nikola Radovanovic » 05.01.09, 15:09
unsrew the pcb , conect it on pc3000, wait until buisy is off.
procede to wdc marvel, pres cancel, select Kernel mode and press Auto detect.
I am on skype : ranikolahdd
Postby AJ2008 » 05.01.09, 16:18
there are pictures in this forum in the WD section showing how to place WD drives into Kernel mode
