i have a disk that when start is in safemode,
he lost the FW
i need the Fw for this model,
Anyone have one like this.
MODEL: 6L200M004641A
CODE: BANC1E00
SN:L407HC4H
Jose
NEED FIRMWARE FOR 6L200M004641A
- Sergey Yatsenko
Do you try to run this drive to alternative SA?
For this you may use option in start dialog of UDMA version which called "Firmware start" - "Start from alternate SA (SATA)".
This option must be run if sefe mode adapter is connected, it called "PC-MX-SAFE" and goes in UDMA version set.
If drive start from ALT-SA correctly you can run "Test servo lables" from Tools - Utility Extantion menu.
ACE Laboratory, PC-3000 Developer
I have connect the drive in SAFEMODE:
Them i try to do Several Things.
Nothing Happen to this !!!
Them i do a soft reset
Them upload from the database
It give this error
Them do other option
Them it gives this error
When i try to run the UTILITY
Can anyone by this pictures helpme.
I notice that the disk have lost the Firmware.
When i give power to the disk, i notice that the disk´s "sing" !!!
Also when i connect the ADAPATOR for the safe mode, it dont give anylight
Jose
It give this error
Jose
- Sergey Yatsenko
When you perform "Start from alternate SA" command HDD must start code from surface if system head is working (can read data).
If drive busy very long time that means SA surface can't read.
Runing loader or so doesn't help! (current PC-3000 UDMA version don't run loader correctly in automatic way).
Problem with reading caused by lubricant loss from spindle motor. In this case drive head become very slow but not knock.
This summer we going to release utility which allow run drives without SA working correctly.
For your case I recomend try clear heads or heads transplant. But for sure check PCB. You may use for it any drive with "BANC1E00" code on top lable.
Users browsing this forum: No registered users and 2 guests
