wd hdd needs
compuman
wd hdd needs
Postby compuman » 29.05.08, 10:22
and thank you for answering
I need resources for WD5000AAKS-00YGA0 with firmware:00580076
and I need also resources for WD1200BEVS-00UST0 with firmware:00040094
At last i have a WD800JB-00FMA0 with RAM error and i want somebody to msn messenger, so to drop the report i get to help me
dmarques
Postby dmarques » 29.05.08, 11:38
For the WD5000AAKS-00YGA0 and the WD1200BEVS-00UST0 I don't have resources.
For the WD800JB-00FMA0, try to swap PCB for a compatible one and check it again.
compuman
wd hdd
Postby compuman » 29.05.08, 11:44
Where else shall i look for resources?
For wd800jb i already done the swap and i want you to see my reports
Please!
dmarques
Postby dmarques » 30.05.08, 09:51
Well, if no one has resources, the only way you have is to find a donor drive to get the resources.
Please post the results you had.
compuman
Postby compuman » 30.05.08, 11:21
    SA Structure test
    Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
    01: 0 : As : -1: 0: 0: 2:Yes : Ok : Ok : 53 :30-06-04:13D7? :Modules directory
    01: 1 : As : -1: 1: 0: 2:Yes : Ok : Ok : 53 :30-06-04:13D7? :Modules directory
    17: 0 : B : -1: 0: 6: 29:Yes : Ok : Ok : 3C :04-06-04:13D7G :Loaded part of microprogram code
    17: 1 : B : -1: 1: 6: 29:Yes : Ok : Ok : 3C :04-06-04:13D7G :Loaded part of microprogram code
    1B: 0 : B : -1: 0: 45: 86:Yes : Ok : Ok : 45 :04-06-04:13D7G :Loaded part of microprogram code
    1B: 1 : B : -1: 1: 45: 86:Yes : Ok : Ok : 45 :04-06-04:13D7G :Loaded part of microprogram code
    4C: 0 : B : -1: 0: 141: 11:Yes : Ok : Ok : 64 :04-06-04:13D7G :Loaded part of microprogram code
    4C: 1 : B : -1: 1: 141: 11:Yes : Ok : Ok : 64 :04-06-04:13D7G :Loaded part of microprogram code
    15: 0 : B : -1: 0: 162: 13:Yes : Ok : Ok : 54 :04-06-04:13D7G :Loaded part of microprogram code
    15: 1 : B : -1: 1: 162: 13:Yes : Ok : Ok : 54 :04-06-04:13D7G :Loaded part of microprogram code
    1E: 0 : B : -1: 0: 185: 23:Yes : Ok : Ok : 67 :04-06-04:13D7G :Loaded part of microprogram code
    1E: 1 : B : -1: 1: 185: 23:Yes : Ok : Ok : 67 :04-06-04:13D7G :Loaded part of microprogram code
    12: 0 : B : -1: 0: 218: 37:Yes : Ok : Ok : 01 :04-06-04:13D7G :Loaded part of microprogram code
    12: 1 : B : -1: 1: 218: 37:Yes : Ok : Ok : 01 :04-06-04:13D7G :Loaded part of microprogram code
    1C: 0 : B : -1: 0: 265: 27:Yes : Ok : Ok : 3E :04-06-04:13D7G :Loaded part of microprogram code
    1C: 1 : B : -1: 1: 265: 27:Yes : Ok : Ok : 3E :04-06-04:13D7G :Loaded part of microprogram code
    13: 0 : B : -1: 0: 302: 22:Yes : Ok : Ok : 02 :04-06-04:13D7G :Loaded part of microprogram code
    13: 1 : B : -1: 1: 302: 22:Yes : Ok : Ok : 02 :04-06-04:13D7G :Loaded part of microprogram code
    11: 0 : B : -1: 0: 334: 187:Yes : Ok : Ok : 3D :04-06-04:13D7G :Loaded part of microprogram code
    11: 1 : B : -1: 1: 334: 187:Yes : Ok : Ok : 3D :04-06-04:13D7G :Loaded part of microprogram code
    35: 0 : Dd : -2: 0: 0: 1:Yes : Ok : Ok : AC :13-10-02:6000? :SA Defects
    35: 1 : Dd : -2: 1: 0: 1:Yes : Ok : Ok : AC :13-10-02:6000? :SA Defects
    02: 0 : B : -2: 0: 5: 2:Yes : Ok : Ok : 6B :04-06-04:0800? :Configuration (HDD ID)
    02: 1 : B : -2: 1: 5: 2:Yes : Ok : Ok : 6B :04-06-04:0800? :Configuration (HDD ID)
    33: 0 : Dd : -2: 0: 11: 290:Yes : Ok : Ok : BE :04-06-04:1500? :P-List (Primary defect list)
    33: 1 : Dd : -2: 1: 11: 290:Yes : Ok : Ok : BE :04-06-04:1500? :P-List (Primary defect list)
    34: 0 : C : -2: 0: 305: 12:Yes : Ok : Ok : AD :04-06-04:1500? :G-List (Grown defect list)
    34: 1 : C : -2: 1: 305: 12:Yes : Ok : Ok : AD :04-06-04:1500? :G-List (Grown defect list)
    31: 0 : Ad : -2: 0: 321: 176:Yes : Ok : Ok : C2 :20-08-49:1500? :Translator
    31: 1 : Ad : -2: 1: 321: 176:Yes : Ok : Ok : C2 :20-08-49:1500? :Translator
    32: 0 : Ad : -2: 0: 501: 8:Yes : Ok : Ok : 23 :20-08-49:1500? :Translator
    32: 1 : Ad : -2: 1: 501: 8:Yes : Ok : Ok : 23 :20-08-49:1500? :Translator
    50: 0 : As : -2: 0: 513: 2:Yes : Ok : Ok : 83 :04-06-04:13D7? :Parameters table 1
    50: 1 : As : -2: 1: 513: 2:Yes : Ok : Ok : 83 :04-06-04:13D7? :Parameters table 1
    51: 0 : As : -2: 0: 519: 2:Yes : Ok : Ok : 11 :04-06-04:13D7? :Parameters table 2
    51: 1 : As : -2: 1: 519: 2:Yes : Ok : Ok : 11 :04-06-04:13D7? :Parameters table 2
    52: 0 : As : -2: 0: 525: 2:Yes : Ok : Ok : 33 :04-06-04:13D7? :Parameters table 3
    52: 1 : As : -2: 1: 525: 2:Yes : Ok : Ok : 33 :04-06-04:13D7? :Parameters table 3
    53: 0 : As : -2: 0: 531: 2:Yes : Ok : Ok : 99 :04-06-04:13D7? :Parameters table 4
    53: 1 : As : -2: 1: 531: 2:Yes : Ok : Ok : 99 :04-06-04:13D7? :Parameters table 4
    36: 0 : : -2: 0: 537: 1:Yes : Ok : Ok : 7C :04-06-04:13D7? :
    36: 1 : : -2: 1: 537: 1:Yes : Ok : Ok : 7C :04-06-04:13D7? :
    2F: 0 : B : -2: 0: 542: 5:Yes : Ok : Ok : 7E :04-06-04:13D7G :Loaded part of microprogram code
    2F: 1 : B : -2: 1: 542: 5:Yes : Ok : Ok : 7E :04-06-04:13D7G :Loaded part of microprogram code
    28: 0 : : -2: 0: 551: 16:Yes : Ok : Ok : F6 :29-06-04:....? :
    28: 1 : : -2: 1: 551: 16:Yes : Ok : Ok : F6 :29-06-04:....? :
    0C: 0 : B : -2: 0: 571: 3:Yes : Ok : Ok : 8F :04-06-04:0100? :Models table
    0C: 1 : B : -2: 1: 571: 3:Yes : Ok : Ok : 8F :04-06-04:0100? :Models table
    2A: 0 : B : -2: 0: 578: 4:Yes : Ok : Ok : F9 :04-06-04:13D7? :Loaded part of microprogram code
    2A: 1 : B : -2: 1: 578: 4:Yes : Ok : Ok : F9 :04-06-04:13D7? :Loaded part of microprogram code
    29: 0 : : -2: 0: 586: 4:Yes : Ok : Ok : 89 :04-06-04:13D7? :
    29: 1 : : -2: 1: 586: 4:Yes : Ok : Ok : 89 :04-06-04:13D7? :
    60: 0 : : -2: 0: 594: 129:Yes : Ok : Ok : F3 :04-06-04:13D7? :
    60: 1 : : -2: 1: 594: 129:Yes : Ok : Ok : F3 :04-06-04:13D7? :
    40: 0 : As : -3: 0: 0: 18:Yes : Ok : Ok : AC :04-06-04:13D7? :Adaptive data
    40: 1 : As : -3: 1: 0: 18:Yes : Ok : Ok : AC :04-06-04:13D7? :Adaptive data
    41: 0 : As : -3: 0: 22: 18:Yes : Ok : Ok : A6 :04-06-04:13D7? :Adaptive data
    41: 1 : As : -3: 1: 22: 18:Yes : Ok : Ok : A6 :04-06-04:13D7? :Adaptive data
    42: 0 : As : -3: 0: 44: 18:Yes : Ok : Ok : F9 :04-06-04:13D7? :Adaptive data
    42: 1 : As : -3: 1: 44: 18:Yes : Ok : Ok : F9 :04-06-04:13D7? :Adaptive data
    43: 0 : As : -3: 0: 66: 18:Yes : Ok : Ok : 80 :04-06-04:13D7? :Adaptive data
    43: 1 : As : -3: 1: 66: 18:Yes : Ok : Ok : 80 :04-06-04:13D7? :Adaptive data
    49: 0 : As : -3: 0: 88: 2:Yes : Ok : Ok : 36 :04-06-04:13D7? :Adaptive data
    49: 1 : As : -3: 1: 88: 2:Yes : Ok : Ok : 36 :04-06-04:13D7? :Adaptive data
    4A: 0 : As : -3: 0: 94: 4:Yes : Ok : Ok : 2A :04-06-04:13D7? :Adaptive data
    4A: 1 : As : -3: 1: 94: 4:Yes : Ok : Ok : 2A :04-06-04:13D7? :Adaptive data
    04: 0 : B : -3: 0: 102: 8:Yes : Ok : Ok : AD :04-06-04:0200? :Family models configuration (Main)
    04: 1 : B : -3: 1: 102: 8:Yes : Ok : Ok : AD :04-06-04:0200? :Family models configuration (Main)
    05: 0 : B : -3: 0: 114: 9:Yes : Ok : Ok : 9F :04-06-04:0200? :Family models configuration (Alt1)
    05: 1 : B : -3: 1: 114: 9:Yes : Ok : Ok : 9F :04-06-04:0200? :Family models configuration (Alt1)
    06: 0 : B : -3: 0: 127: 8:Yes : Ok : Ok : 67 :04-06-04:0200? :Family models configuration (Alt2)
    06: 1 : B : -3: 1: 127: 8:Yes : Ok : Ok : 67 :04-06-04:0200? :Family models configuration (Alt2)
    07: 0 : B : -3: 0: 139: 8:Yes : Ok : Ok : 6E :04-06-04:0200? :Family models configuration (Alt3)
    07: 1 : B : -3: 1: 139: 8:Yes : Ok : Ok : 6E :04-06-04:0200? :Family models configuration (Alt3)
    21: 0 : B : -8: 0: 0: 51:Yes : Ok : Ok : E1 :04-06-04:2102? :S.M.A.R.T.
    21: 1 : B : -8: 1: 0: 51:Yes : Ok : Ok : E1 :04-06-04:2102? :S.M.A.R.T.
    22: 0 : B : -8: 0: 55: 51:Yes : Ok : Ok : E0 :04-06-04:2102? :S.M.A.R.T.
    22: 1 : B : -8: 1: 55: 51:Yes : Ok : Ok : E0 :04-06-04:2102? :S.M.A.R.T.
    23: 0 : B : -8: 0: 110: 51:Yes : Ok : Ok : 4C :04-06-04:2102? :S.M.A.R.T. Log (reserved)
    23: 1 : B : -8: 1: 110: 51:Yes : Ok : Ok : 4C :04-06-04:2102? :S.M.A.R.T. Log (reserved)
    24: 0 : B : -8: 0: 165: 51:Yes : Ok : Ok : 4B :04-06-04:2102? :S.M.A.R.T. Log (reserved)
    24: 1 : B : -8: 1: 165: 51:Yes : Ok : Ok : 4B :04-06-04:2102? :S.M.A.R.T. Log (reserved)
    25: 0 : : -8: 0: 220: 33:Yes : Ok : Ok : 8E :04-06-04:13D7? :
    25: 1 : : -8: 1: 220: 33:Yes : Ok : Ok : 8E :04-06-04:13D7? :
    26: 0 : : -8: 0: 257: 25:Yes : Ok : Ok : 95 :04-06-04:13D7? :
    26: 1 : : -8: 1: 257: 25:Yes : Ok : Ok : 95 :04-06-04:13D7? :
    2D: 0 : : -8: 0: 286: 192:Yes : Ok : Ok : E7 :04-06-04:13D7? :
    2D: 1 : : -8: 1: 286: 192:Yes : Ok : Ok : E7 :04-06-04:13D7? :
    2E: 0 : B : -8: 0: 482: 192:Yes : Ok : Ok : E6 :04-06-04:13D7? :Loaded part of microprogram code
    2E: 1 : B : -8: 1: 482: 192:Yes : Ok : Ok : E6 :04-06-04:13D7? :Loaded part of microprogram code
    C4: 0 : Dr : -1: 0: 531: 91:Yes : Ok : Ok : F3 :09-06-04:O.07? :Calibrations module
    C4: 1 : Dr : -1: 1: 531: 91:Yes : Ok : Ok : F3 :09-06-04:O.07? :Calibrations module
    C5: 0 : Dr : -1: 0: 622: 4:Yes : Ok : Ok : BA :09-06-04:O.06? :Calibration script (DCM)
    C5: 1 : Dr : -1: 1: 622: 4:Yes : Ok : Ok : BA :09-06-04:O.06? :Calibration script (DCM)
    C1: 0 : Dr : -1: 0: 626: 1:Yes : Ok : Ok : ED :09-06-04:O.07? :Calibrations module
    C1: 1 : Dr : -1: 1: 626: 1:Yes : Ok : Ok : ED :09-06-04:O.07? :Calibrations module
    C2: 0 : Dr : -1: 0: 627: 1:Yes : Ok : Ok : DD :09-06-04:O.07? :Calibrations module
    C2: 1 : Dr : -1: 1: 627: 1:Yes : Ok : Ok : DD :09-06-04:O.07? :Calibrations module
    CC: 0 : Dr : -1: 0: 628: 6:Yes : Ok : Ok : 26 :09-06-04:O.07? :Calibrations module
    CC: 1 : Dr : -1: 1: 628: 6:Yes : Ok : Ok : 26 :09-06-04:O.07? :Calibrations module
    C7: 0 : Dr : -1: 0: 634: 1:Yes : Ok : Ok : 02 :09-06-04:O.07? :Calibrations module
    C7: 1 : Dr : -1: 1: 634: 1:Yes : Ok : Ok : 02 :09-06-04:O.07? :Calibrations module
    CA: 0 : Dr : -1: 0: 635: 6:Yes : Ok : Ok : FE :09-06-04:O.07? :Calibrations module
    CA: 1 : Dr : -1: 1: 635: 6:Yes : Ok : Ok : FE :09-06-04:O.07? :Calibrations module
    CB: 0 : Dr : -1: 0: 641: 6:Yes : Ok : Ok : C3 :09-06-04:O.07? :Calibrations module
    CB: 1 : Dr : -1: 1: 641: 6:Yes : Ok : Ok : C3 :09-06-04:O.07? :Calibrations module
    CD: 0 : Dr : -1: 0: 647: 6:Yes : Ok : Ok : 82 :09-06-04:O.07? :Calibrations module
    CD: 1 : Dr : -1: 1: 647: 6:Yes : Ok : Ok : 82 :09-06-04:O.07? :Calibrations module
    CF: 0 : Dr : -1: 0: 653: 6:Yes : Ok : Ok : F5 :09-06-04:O.07? :Calibrations module
    CF: 1 : Dr : -1: 1: 653: 6:Yes : Ok : Ok : F5 :09-06-04:O.07? :Calibrations module
    CE: 0 : Dr : -1: 0: 659: 6:Yes : Ok : Ok : F3 :09-06-04:O.07? :Calibrations module
    CE: 1 : Dr : -1: 1: 659: 6:Yes : Ok : Ok : F3 :09-06-04:O.07? :Calibrations module
    B1: 0 : : -1: 0: 665: 5:Yes : Ok : Ok : 33 :09-06-04:0107? :
    B1: 1 : : -1: 1: 665: 5:Yes : Ok : Ok : 33 :09-06-04:0107? :
    E0: 0 : Dr : -6: 0: 0: 600:Yes : Ok : Ok : 73 :09-06-04:614G? :Selfscan module
    E0: 1 : Dr : -6: 1: 0: 600:Yes : Ok : Ok : 73 :09-06-04:614G? :Selfscan module
    E8: 0 : Dr : -3: 0: 151: 429:Yes : Ok : Ok : 87 :09-06-04:614G? :Selfscan module
    E8: 1 : Dr : -3: 1: 151: 429:Yes : Ok : Ok : 87 :09-06-04:614G? :Selfscan module
    FE: 0 : Dr : -1: 0: 670: 128:Yes : Ok : Ok : 4D :09-06-04:614G? :Selfscan module
    FE: 1 : Dr : -1: 1: 670: 128:Yes : Ok : Ok : 4D :09-06-04:614G? :Selfscan module
    D5: 0 : Dr : -3: 0: 580: 104:Yes : Ok : Ok : E5 :09-06-04:614G? :Selfscan module
    D5: 1 : Dr : -3: 1: 580: 104:Yes : Ok : Ok : E5 :09-06-04:614G? :Selfscan module
    DF: 0 : Dr : -3: 0: 684: 88:Yes : Ok : Ok : F2 :09-06-04:614G? :Selfscan module
    DF: 1 : Dr : -3: 1: 684: 88:Yes : Ok : Ok : F2 :09-06-04:614G? :Selfscan module
    D4: 0 : Dr : -2: 0: 727: 67:Yes : Ok : Ok : FF :09-06-04:614G? :Selfscan module
    D4: 1 : Dr : -2: 1: 727: 67:Yes : Ok : Ok : FF :09-06-04:614G? :Selfscan module
    DD: 0 : Dr : -6: 0: 600: 83:Yes : Ok : Ok : 5A :09-06-04:614G? :Selfscan module
    DD: 1 : Dr : -6: 1: 600: 83:Yes : Ok : Ok : 5A :09-06-04:614G? :Selfscan module
    D2: 0 : Dr : -6: 0: 683: 81:Yes : Ok : Ok : 8E :09-06-04:614G? :Selfscan module
    D2: 1 : Dr : -6: 1: 683: 81:Yes : Ok : Ok : 8E :09-06-04:614G? :Selfscan module
    D3: 0 : Dr : -7: 0: 0: 66:Yes : Ok : Ok : D2 :09-06-04:614G? :Selfscan module
    D3: 1 : Dr : -7: 1: 0: 66:Yes : Ok : Ok : D2 :09-06-04:614G? :Selfscan module
    DA: 0 : Dr : -7: 0: 66: 85:Yes : Ok : Ok : 53 :09-06-04:614G? :Selfscan module
    DA: 1 : Dr : -7: 1: 66: 85:Yes : Ok : Ok : 53 :09-06-04:614G? :Selfscan module
    DB: 0 : Dr : -7: 0: 151: 86:Yes : Ok : Ok : 96 :09-06-04:614G? :Selfscan module
    DB: 1 : Dr : -7: 1: 151: 86:Yes : Ok : Ok : 96 :09-06-04:614G? :Selfscan module
    D0: 0 : Dr : -7: 0: 237: 66:Yes : Ok : Ok : 28 :09-06-04:614G? :Selfscan module
    D0: 1 : Dr : -7: 1: 237: 66:Yes : Ok : Ok : 28 :09-06-04:614G? :Selfscan module
    D6: 0 : Dr : -7: 0: 303: 83:Yes : Ok : Ok : 3D :09-06-04:614G? :Selfscan module
    D6: 1 : Dr : -7: 1: 303: 83:Yes : Ok : Ok : 3D :09-06-04:614G? :Selfscan module
    D7: 0 : Dr : -7: 0: 386: 81:Yes : Ok : Ok : 9A :09-06-04:614G? :Selfscan module
    D7: 1 : Dr : -7: 1: 386: 81:Yes : Ok : Ok : 9A :09-06-04:614G? :Selfscan module
    D9: 0 : Dr : -7: 0: 467: 71:Yes : Ok : Ok : 9B :09-06-04:614G? :Selfscan module
    D9: 1 : Dr : -7: 1: 467: 71:Yes : Ok : Ok : 9B :09-06-04:614G? :Selfscan module
    DC: 0 : Dr : -7: 0: 538: 67:Yes : Ok : Ok : E5 :09-06-04:614G? :Selfscan module
    DC: 1 : Dr : -7: 1: 538: 67:Yes : Ok : Ok : E5 :09-06-04:614G? :Selfscan module
    B9: 0 : Dr : -7: 0: 605: 60:Yes : Ok : Ok : 7E :09-06-04:614G? :Selfscan module
    B9: 1 : Dr : -7: 1: 605: 60:Yes : Ok : Ok : 7E :09-06-04:614G? :Selfscan module
    BA: 0 : Dr : -7: 0: 665: 61:Yes : Ok : Ok : CD :09-06-04:614G? :Selfscan module
    BA: 1 : Dr : -7: 1: 665: 61:Yes : Ok : Ok : CD :09-06-04:614G? :Selfscan module
    BB: 0 : Dr : -7: 0: 726: 72:Yes : Ok : Ok : CA :09-06-04:614G? :Selfscan module
    BB: 1 : Dr : -7: 1: 726: 72:Yes : Ok : Ok : CA :09-06-04:614G? :Selfscan module
    FD: 0 : Dr : -8: 0: 678: 64:Yes : Ok : Ok : 6A :09-06-04:614G? :Selfscan module
    FD: 1 : Dr : -8: 1: 678: 64:Yes : Ok : Ok : 6A :09-06-04:614G? :Selfscan module
    FB: 0 : Dr : -3: 0: 772: 32:Yes : Ok : Ok : 77 :/WRONG/ :614G? :Selfscan module
    FB: 1 : Dr : -3: 1: 772: 32:Yes : Ok : Ok : 77 :/WRONG/ :614G? :Selfscan module
    E6: 0 : Dr : -6: 0: 764: 32:Yes : Ok : Ok : A1 :09-06-04:614G? :Selfscan module
    E6: 1 : Dr : -6: 1: 764: 32:Yes : Ok : Ok : A1 :09-06-04:614G? :Selfscan module
    E7: 0 : Dr : -8: 0: 742: 32:Yes : Ok : Ok : FA :05-02-04:....? :Selfscan module
    E7: 1 : Dr : -8: 1: 742: 32:Yes : Ok : Ok : FA :05-02-04:....? :Selfscan module
    BE: 0 : Dr : -8: 0: 774: 21:Yes : Ok : Ok : E2 :09-06-04:614G? :Selfscan module
    BE: 1 : Dr : -8: 1: 774: 21:Yes : Ok : Ok : E2 :09-06-04:614G? :Selfscan module
    B8: 0 : Dr : -1: 0: 798: 8:Yes : Ok : Ok : 92 :29-06-04:614G? :Selfscan module
    B8: 1 : Dr : -1: 1: 798: 8:Yes : Ok : Ok : 92 :29-06-04:614G? :Selfscan module
    BD: 0 : : -1: 0: 806: 1:Yes : Ok : Ok : 0C :09-06-04:614G? :
    BD: 1 : : -1: 1: 806: 1:Yes : Ok : Ok : 0C :09-06-04:614G? :
    BF: 0 : Dr : -2: 0: 794: 8:Yes : Ok : Ok : C2 :09-06-04:614G? :Selfscan module
    BF: 1 : Dr : -2: 1: 794: 8:Yes : Ok : Ok : C2 :09-06-04:614G? :Selfscan module
    FC: 0 : Dr : -2: 0: 802: 4:Yes : Ok : Ok : C4 :09-06-04:614G? :Selfscan module
    FC: 1 : Dr : -2: 1: 802: 4:Yes : Ok : Ok : C4 :09-06-04:614G? :Selfscan module
    EE: 0 : Dr : -2: 0: 806: 4:Yes : Ok : Ok : 85 :09-06-04:614G? :Selfscan module
    EE: 1 : Dr : -2: 1: 806: 4:Yes : Ok : Ok : 85 :09-06-04:614G? :Selfscan module
    E1: 0 : Dr : -10: 0: 0: 600:Yes : Ok : Ok : F2 :09-06-04:614G? :Selfscan module
    E1: 1 : Dr : -10: 1: 0: 600:Yes : Ok : Ok : F2 :09-06-04:614G? :Selfscan module
    E2: 0 : Dr : -11: 0: 0: 600:Yes : Ok : Ok : DC :09-06-04:614G? :Selfscan module
    E2: 1 : Dr : -11: 1: 0: 600:Yes : Ok : Ok : DC :09-06-04:614G? :Selfscan module
    E3: 0 : Dr : -12: 0: 0: 600:Yes : Ok : Ok : DB :09-06-04:614G? :Selfscan module
    E3: 1 : Dr : -12: 1: 0: 600:Yes : Ok : Ok : DB :09-06-04:614G? :Selfscan module
    E4: 0 : Dr : -13: 0: 0: 600:Yes : Ok : Ok : DA :09-06-04:614G? :Selfscan module
    E4: 1 : Dr : -13: 1: 0: 600:Yes : Ok : Ok : DA :09-06-04:614G? :Selfscan module
    E5: 0 : Dr : -14: 0: 0: 600:Yes : Ok : Ok : D9 :09-06-04:614G? :Selfscan module
    E5: 1 : Dr : -14: 1: 0: 600:Yes : Ok : Ok : D9 :09-06-04:614G? :Selfscan module
    E9: 0 : Dr : -9: 0: 0: 429:Yes : Ok : Ok : 78 :09-06-04:614G? :Selfscan module
    E9: 1 : Dr : -9: 1: 0: 429:Yes : Ok : Ok : 78 :09-06-04:614G? :Selfscan module
    Zone allocation table
    HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
    MODULES DIRECTORY (01)
    SA Copy num Location State
    0 c: -1 H: 0 Ok
    1 c: -1 H: 1 Ok
    Modules number.......................... : 92
    CONFIGURATION MODULE (02)
    0 c: -2 H: 0 Ok
    1 c: -2 H: 1 Ok
    HDD Identify
    Model................................... : WDC WD800JB-00FMA0
    Serial number........................... : WD-WCAJ93366228.....
    Logical parameters...................... : LBA : 156 301 487
    Master-password
    Set..................................... : No
    User-password
    Security level.......................... : High
    Log DCM (C5)
    0 c: -1 H: 0 Ok
    1 c: -1 H: 1 Ok
    MAMMOTH MAM 48
    + MAM codata O.06 ----- Drive Head DCM Codes -----+
    | WDB: 0, 7, F, Y ( zero offset head) |
    | WDB-HBMT: M ( zero offset head) |
    | HEADWAY: 8, D ( zero-offset head) |
    | ALPS: A ( zero-offset head) |
    | ALPS: H, J, L, R (non-zero offset head) |
    Avalable scripts
    "B" - B8MAMO.06
    "_" - _8MAMO.06
    "V" - V8MAMO.06
    "T" - T8MAMO.06
    "A" - A8MAMO.06
    "C" - C8MAMO.06
    P-List (33)
    0 c: -2 H: 0 Ok
    1 c: -2 H: 1 Ok
    Defects number.......................... : 714
    G-List (34)
    0 c: -2 H: 0 Ok
    1 c: -2 H: 1 Ok
    Defects number.......................... : 0
Modules checking
Module 01............................... : Ok
Module 17............................... : Ok
Module 1B............................... : Ok
Module 4C............................... : Ok
Module 15............................... : Ok
Module 1E............................... : Ok
Module 12............................... : Ok
Module 1C............................... : Ok
Module 13............................... : Ok
Module 11............................... : Ok
Module 35............................... : Ok
Module 02............................... : Ok
Module 33............................... : Ok
Module 34............................... : Ok
Module 31............................... : Ok
Module 32............................... : Ok
Module 50............................... : Ok
Module 51............................... : Ok
Module 52............................... : Ok
Module 53............................... : Ok
Module 36............................... : Ok
Module 2F............................... : Ok
Module 28............................... : Ok
Module 0C............................... : Ok
Module 2A............................... : Ok
Module 29............................... : Ok
Module 60............................... : Ok
Module 40............................... : Ok
Module 41............................... : Ok
Module 42............................... : Ok
Module 43............................... : Ok
Module 49............................... : Ok
Module 4A............................... : Ok
Module 04............................... : Ok
Module 05............................... : Ok
Module 06............................... : Ok
Module 07............................... : Ok
Module 21............................... : Ok
Module 22............................... : Ok
Module 23............................... : Ok
Module 24............................... : Ok
Module 25............................... : Ok
Module 26............................... : Ok
Module 2D............................... : Ok
Module 2E............................... : Ok
Module C4............................... : Ok
Module C5............................... : Ok
Module C1............................... : Ok
Module C2............................... : Ok
Module CC............................... : Ok
Module C7............................... : Ok
Module CA............................... : Ok
Module CB............................... : Ok
Module CD............................... : Ok
Module CF............................... : Ok
Module CE............................... : Ok
Module B1............................... : Ok
Module E0............................... : Ok
Module E8............................... : Ok
Module FE............................... : Ok
Module D5............................... : Ok
Module DF............................... : Ok
Module D4............................... : Ok
Module DD............................... : Ok
Module D2............................... : Ok
Module D3............................... : Ok
Module DA............................... : Ok
Module DB............................... : Ok
Module D0............................... : Ok
Module D6............................... : Ok
Module D7............................... : Ok
Module D9............................... : Ok
Module DC............................... : Ok
Module B9............................... : Ok
Module BA............................... : Ok
Module BB............................... : Ok
Module FD............................... : Ok
Module FB............................... : Ok
Module E6............................... : Ok
Module E7............................... : Ok
Module BE............................... : Ok
Module B8............................... : Ok
Module BD............................... : Ok
Module BF............................... : Ok
Module FC............................... : Ok
Module EE............................... : Ok
Module E1............................... : Ok
Module E2............................... : Ok
Module E3............................... : Ok
Module E4............................... : Ok
Module E5............................... : Ok
Module E9............................... : Ok
    SA surface verification
    Cyl: -1 Head: 0......................... : Ok
    Cyl: -1 Head: 1......................... : Ok
    Cyl: -2 Head: 0......................... : Ok
    Cyl: -2 Head: 1......................... : Ok
    Cyl: -3 Head: 0......................... : Ok
    Cyl: -3 Head: 1......................... : Ok
    Cyl: -4 Head: 0......................... : Ok
    Cyl: -4 Head: 1......................... : Ok
    Cyl: -5 Head: 0......................... : Ok
    Cyl: -5 Head: 1......................... : Ok
    Cyl: -6 Head: 0......................... : Ok
    Cyl: -6 Head: 1......................... : Ok
    Cyl: -7 Head: 0......................... : Ok
    Cyl: -7 Head: 1......................... : Ok
    Cyl: -8 Head: 0......................... : Ok
    Cyl: -8 Head: 1......................... : Ok
    Cyl: -9 Head: 0......................... : Ok
    Cyl: -9 Head: 1......................... : Ok
    Cyl: -10 Head: 0........................ : Ok
    Cyl: -10 Head: 1........................ : Ok
    Cyl: -11 Head: 0........................ : Ok
    Cyl: -11 Head: 1........................ : Ok
    Cyl: -12 Head: 0........................ : Ok
    Cyl: -12 Head: 1........................ : Ok
    Cyl: -13 Head: 0........................ : Ok
    Cyl: -13 Head: 1........................ : Ok
    Cyl: -14 Head: 0........................ : Ok
    Cyl: -14 Head: 1........................ : Ok
    Cyl: -15 Head: 0........................ : Ok
    Cyl: -15 Head: 1........................ : Ok
    Cyl: -16 Head: 0........................ : Ok
    Cyl: -16 Head: 1........................ : Ok
    Cyl: -17 Head: 0........................ : Ok
    Cyl: -17 Head: 1........................ : Ok
    Cyl: -18 Head: 0........................ : Ok
    Cyl: -18 Head: 1........................ : Ok
    Cyl: -19 Head: 0........................ : Ok
    Cyl: -19 Head: 1........................ : Ok
Postby ACE_Admin » 04.06.08, 09:13
As we can see there are no errors exept the error bellow:
the problem was solved by resoldering the ROM from patient PCB to donor
