Hi guys
Does anyone know the terminal connection for Seagate ST31000340AS? I tried using the 4 pins (next to SATA data cable) but the terminal shows nothing.
Seagate 1T bytes terminal connection
Command for 7200.11 drives
hi
Open Hypertermianl in connection in windows
Start > programs> communication> hyperterminal
select the USB terminal comport (my is Com 3)
set the baudrate to 38400
power on the drive through pc3000 and the you can see terminal working.
but many command are changed. in 7200.11 model.
i.e if you do Crtl + c the disk will spin down.
for more help in this model you have to press Crtl +L
I am also looking for more command on these drive if any one has explored please share.
DF
DF
