Maxtor ARES 64K 2F020J0 (VAM51JJ0) 'Initialization error'
DR_Ireland
Postby DR_Ireland » 15.12.07, 18:17
Greetings everybody!
HDD is spinning, cannot hear any knocking and detected by PC3000 UDMA as:
Code: Select all
Model: Maxtor ARES C64K
Serial:
Firmware: VAM51JJZ
Capacity: 38.29GB (80 295 529)
It shows following error when trying to start Utility:
Code: Select all
Context: Read roadmap
Content: Device error detected
Is there any chance to get data back from this drive? I don't have the same drive to create a loader. Any suggestions?
Pawel
Postby ACE_Admin » 17.12.07, 09:54
sorry, for delayed answer, but what is with this drive at this moment?
did you solve it?
if no, then :
what did this drive show you = in its Service area test?
DR_Ireland
Postby DR_Ireland » 18.12.07, 13:04
At this point I cannot een get into an Utility, I am getting 'Initialization error' message box with [OK} and it gets back to detection screen.
I was hoping that with good loader I can at least diagnose it somehow.
DR_Ireland
Postby DR_Ireland » 19.12.07, 14:33
Hi all, I got a loader and started the drive on 'Safe Mode', checked SA and it turned out that G-List is damaged. Cleaned it and restarted the drive in normal mode. Data is accessible in Data Extractor.
Greetings all. Pawel
Towerrat79
Re: Maxtor ARES 64K 2F020J0 (VAM51JJ0) 'Initialization error
Postby Towerrat79 » 13.05.13, 10:50
Thank you for posting how you were able to recover the data. I have a similar drive that I just fixed.
Frank
Frank Meincke
Gefund-IT (Datenrettung)
Daimlerstrasse 70
74545 Michelfeld
tel: 0791-94 66 68 52
email: Info@Gefund-IT.de
web: www.Gefund-IT.de
Return to “Maxtor”
