Seagate ST380819AS SMART Problems
Postby ACE_Admin » 26.09.07, 15:40
The problem happens with ST380819AS Seagate hard drive
It didnt show its Model and serial numbers and its capacity was set to 49 mb(first 999 sectors)
In the terminal it displayed the text bellow:
Code: Select all
Interface task reset
4096k x 16 buffer detected
PUMA2 - 1_Disk    0.03  12-12-05 14:40
              Spin Ready
3.04  12-12-05 14:42  4096k x 16 buffer
(P)SATA Reset
Restore
Age=50 Type=C9 MxCyl=164F7 MxHd=1 MxSct=44C BSz=2000 TCode=00000000
The drive reads its first 999 sectors perfectly, but it cant read the rest of them.
How to solve :
1. Going to terminal mode, and waiting until the drive goes ready
2. Pressing the ctrl-z button will follow you to T> mode. The promt will look like T>
3. Entering the first level - type /1 and press enter
The promt will turn to 1>
4. type N0, this will output something like that :
Initializing SMART Sectors...................................
now, the smart logs are cleared
tea
ya ! please give more TS repair skill
Postby tea » 17.11.07, 08:21
thank you !!!!
tea
Barracuda 7200.9 Tonka2 ST3808110AS Problem ?
Postby tea » 02.03.08, 08:53
005f 0000 0004
DiskAccess ReadSector EC=43 at 0221f5.00.0004
CE Log ErrCode=37 LBA=925d9bf Type=5 onModGray,133MHz,Code DRAM,Early Exit,Stall Converter,RwFeat=0002,SeaDex,VBAR,MDW
Pgm=00 Trk=221F5(20916:E0[21ED2]).0(0).005(0F6) Zn=E Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=0925D9C0
DiskAccess ReadSector EC=43 at 0221f5.00.0005
CE Log ErrCode=37 LBA=925d9c0 Type=5 Add To Pending 925d9c0
Pgm=00 Trk=221F5(20916:E0[17029]).0(0).006(0F7) Zn=0 Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=0925D9C1
T>/1
1>N0
1>N0
1>
than I try type
1>N1
Initializing SMART Sectors...RPO..................................ENDOK
1>
put how to disable drive S.M.A.R.T recovery of user data
Using Data Extractor . I check BOOK 10.6 53 page
I can't diable my hdd
Max_ACELab
Postby Max_ACELab » 12.03.08, 14:28
Unfortunately on Seagate HDD you can disable only suport of SMART ATA commands. But internal SMART process is wery strong integrated into FW. And can`t be disabled without serious intervention into HDD FW.
ACE Laboratory PC-3000 developer
max@acelab.ru
