ST340014A
Bruno
ST340014A
Postby Bruno » 26.09.07, 14:33
Hi all
I have a Seagate AT340014A, that i dont could read the data.
After start PC3000UDMA Seagate-Utility, a long time is gone, to complete the terminal entrys. Approx. 2 min.
Here is the terminal output:
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz - Head Mask 0000 - Switch to full int.
Spin Ready
3.04 06-11-03 15:19
(P)PATA Reset
CE Log EC=0 Rtype=36 OV=0 STStatus0
AutoRd Err 43 at 00f6ba.00.008b
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
AutoRd Err 43 at 00f6ba.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Master
Read Ver Retrys
Read Ver Retrys
AT Er 00 Nwt Er 47 RdWr c3b0.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 0000c1c3 ff 0000c1c3.0.000 00db 0000 e0e8 0001
AutoRd Err 47 at 00c3b0.00.01f9
CE Log EC=47 Rtype=25 OV=0 STStatus0
Read Ver Retrys
SCAN Error
AutoRd Err 47 at 00f6ba.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AutoRd Err 47 at 00c3b0.00.01fa
Read Ver Retrys
AutoRd Err 43 at 00f6ba.00.0118
Read Ver Retrys
SCAN Error
What could be the problem of this HD?
Thanks for help
Bruno
Postby ACE_Admin » 26.09.07, 15:15
Greetings Bruno
It is probably problem with adaptives or with the PCB. To be sure for this problem you should :
1. unscrew the pcb and check the contacts - clean them if they are dirty
2. swap the pcb with another good and compartible one, and check for terminal's output
