Maxtor 32049H2
Bruno
Maxtor 32049H2
Postby Bruno » 20.09.07, 12:20
Hi all
I have a Question about PC-3000UDMA and Maxtor.
Why, in the Utility start Window, i read in red color:
HDD Save Mode detected
The Jumpers are normaly in Master position.
Model: Maxtor Proxima
Thanks for Answer
Bruno
Postby ACE_Admin » 20.09.07, 13:10
hi Bruno
This usually happens when the SA is damaged.
To recover that drive, you should set the jumpers to save mode , then load proper loader. Then check the system area.
Return to “Maxtor”
