Hi all
I have a ST340016A.
The Util reports LBA=66055248 instead of LBA:78165360
In the UserGuide from PC3000UDMA i dont found articles over headmapping on this "SNOWMASS" drive.
any sugestions?
ST340016A
- Yuriy Manjilevskiy
Dear Yuriy
Thanks for your fast answer.
Your Tip are excelent,
Max LBA restricted to................... : 66 055 248 (135 680 863)
S.M.A.R.T............................... : Ok
Write cache............................. : enabled
but Max LBA set is only functional with RAM, not to service area: "HD does not support Set Max Command..."
This is the output from Seagate util:
Interface task reset
1024k x 16 buffer detected
SNOWMASS - 1_Disk 3.75 11-20-01 13:27
Power Cycling
ATReset
Head Mask 000F - Switch to full int.
Spin Ready
Sweeping 189 Cyls
PMaster
Power Cycling
ATReset
Spin Ready
Sweeping 189 Cyls
PMaster
Dear Yuriy
I have no chance to use your last message.
After shut down the pc for approx. 2Hours i do restart, run the PC-3000UDMA schitch on the power of ATA1 (the connector where the HD is connectet, and knock, knock
this is the Terminal output:
Power Cycling
ATReset
Spin Ready
$Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - Head Mask 000F - NIWOT TIME OUT
At the first time i connected this HD there doing the same, but after he works for any Hours. icould read the ~30GB.
I think Seagate is a hard bread for datarecovery...
Tomorrow is another day.
Power Cycling
ATReset
Spin Ready
