When it starts it picks FIM38B_00 loader, and after initial stage shows:
Code: Select all
Loader uploading
Power Off
Power On
Safe mode............................... : Ok
MPISP code name......................... : W0825A0 FIMN38_00 (XT2); W0621A(N)
W0825A0 FIMN38_00 (XT2); W0621A(N)...... : Ok
Seed table reading
Completed
Microcode reading (0)................... : Ok
Firmware version (Internal)............. : X0419B0 FIM38B_00
SSD parameters reading.................. : Ok
Loader not found by internal name.
Search for compatible loaders...
Loader is not uploaded! Some utility functions may not work properly!
SSD status:
Firmware mode........................... : LDR
SSD error code.......................... : 0x00 (No errors)
Test completed
Drive power supply...................... : OFFBut I don't see X0419B0 FIM38B_00 on the list, and if I select anything else it fails.
NAND chips:
Code: Select all
System Info:
Chips id................................ : 89D3AC32C204
Vendor.................................. : Intel
Type.................................... : 144L(N38) QLC 16k
Chip capacity........................... : 144 000 Mb
Channels................................ : 2
Chips (Total)........................... : 0x04
Planes per chip......................... : 4
LUNs per chip........................... : 1
Blocks per chip......................... : 0x00FA
Pages per block......................... : 0x9000
Page size............................... : 0x4000
Max retry level......................... : 0x00Any help apreciated.
