WD charger USB C to sata conversion HELP PCB PCB 2060-81003
datasalvage
Postby datasalvage » 19.06.25, 08:42
hello there i came across one page regarding "usb C to SATA" conversion by blizzard data for the PCB 2060-81003-001 REV P1 i believe the wiring is correct however i saw another post by chinese person were they did soldering on different PIN numbers so got confused..... do someone know which one is the correct? sorry im getting old
Re: WD charger USB C to sata conversion HELP PCB PCB 2060-81003
Postby digitalsupport » 19.06.25, 10:37
Both are correct and shows the same as i see it.
810003 has reversed connection sequence ( or has wrong pcb makings :shockable: )
Return to “WD USB”
