Standard 10x3 layout, needed voltage dropping to 2.4v/1.8v to get an ID and read the chip database has 3.3v for both.
ECC found and after application the map shows just 4GB invalid. XOR is not being found though. Anyone had any success with these? I moved it over to FE just to check where it's able to build an image with the default model and sector number slow so everything is working and connected properly but I'd prefer to do it in flash if possible.
Sandisk ultra luxe : 453C99B3
Re: Sandisk ultra luxe : 453C99B3
Please make a ticket, and ACELab engineers will guide you with the image building.
Im outside of my support contract period.
