WD40PURX Module 02 Checksum error. No access to data
Postby gameboybin » 31.12.24, 18:40
Hi everyone. Need your help with this case. The drive has bad Head 04 before and wont let Module 02 Write back to upload LDR. After swapping new heads. The drive readies, full access to SA and can read and write to SA normally. However have the Module 02 checksum error. And wont let me access to user Sector
Model : WDC WD40PURX-89T1XY0
Serial : WD-WCC3FTTR0327
Firmware : 00.02C.5
Capacity : 4 TB (7 814 037 168)
Code: Select all
Family:................................. : Giant
System controller (SoC)................. : 88i9446C0 0x(A5C0)
Modules directory address............... : 402 822
SA SPT.................................. : 2116
SA defects assigned..................... : 6
ROM Modules:
ROM version............................. : 00.54C
Module 4F F/W version................... : 00000054
Overlay F/W version..................... : 00.55C
Servo F/W version....................... : 02.49
Relocations............................. : 0 (3 065)
Read ROM DCM............................ : Ok
Power up load dir data.................. : Yes
Power up load permovl................... : Yes
Power up load CFG data.................. : Yes
NN | Step |      Time | Flags | Info | Description
13 | 710A |    672 ms |   501 | 2097 | SET_SOC_POWER_MODE(Unknown error code: 2097)
36 | 710A | 10 621 ms |   501 | 2097 | SET_SOC_POWER_MODE(Unknown error code: 2097)
79 | 710A | 10 311 ms |   501 | 2097 | SET_SOC_POWER_MODE(Unknown error code: 2097)
Service area:
Dir items loaded........................ : 422
CFG tech mode lock...................... : No
Self encryption drive................... : No
DCM in module 47........................ : WM
DCM in module 0A........................ : |F|GWMKCGD
DCM in module 02........................ : S|BFLAPQMWHMCKRSVQKTUG
I have tried uploading LDR + Module 2 from different donors. Still have no access to data. Module 2 still has Checksum error
Thanks for the help!
Screenshot (930).png (495.4 KiB) Viewed 3851 times
XiaoShen
Re: WD40PURX Module 02 Checksum error. No access to data
Postby XiaoShen » 03.01.25, 10:44
Verify write to memory
