WD Blue WD6400AAAKDS
peter.best
Postby peter.best » 29.07.24, 05:52
Hello Team.
Client burned PCB with over volt power connection.
I replaced the PCB. There appears to be no ROM chip to swap.
I run a disk test and see "The drive issues an ABR when you try to read it. It is necessary to perform diagnostics and repair the firmware of the drive.
PCB Test shows Sector Buffer Test Write sector buffer error Port 0) SendCmdDataOut. SendPortCmd
How do I repair this firmware please?
peter.best
Re: WD Blue WD6400AAAKDS
Postby peter.best » 29.07.24, 05:54
Postby AJ2008 » 30.07.24, 18:15
I think for this model PC3K can automate ROM recovery process for you, assuming PCB is only issue.
peter.best
Postby peter.best » 31.07.24, 01:49
Thank you AJ2008
Would you be so kind as to explain how to do this please?
Postby AJ2008 » 31.07.24, 09:39
