FBLite ROM issue
beefstrudel
FBLite ROM issue
Postby beefstrudel » 26.07.24, 14:22
I have this WD10JPVX-75JC3T0 that spins up, heads don't sound like they move.
Status register lights up BSY for only a half a second or so. PHY is on.
If I try to ID the drive or go into utility the BSY register comes back on but never goes ready in kernel mode.
I dumped the ROM and programmed it to a donor board with the same results.
Just wondering if someone can examine this ROM and determine if that is the issue.
I've managed to get the drive ready using a donor rom, and moving SA translator, SA Adaptives, and Heads map over to the donor ROM, but the drive only IDs with serial number and 0 capacity.
Reading module 02 gets VSC ERROR UNSUP ACTION CODE, but I am able to read SA modules by ID.
WD10JPVX-WXV153ZYN05.bin.zip
(243.13 KiB) Downloaded 136 times
Re: FBLite ROM issue
Postby AJ2008 » 30.07.24, 18:15
If you already have SA access try restore ROM from SA modules.
If not, Load LDR with donor ROM (check SA can read, for firebird I think 4F dependency is not present) and search SA for module. Restore ROM
Donor ROM with same version and same offsets in directory start should give access anyway.
