Seagate ST2000DM005 gone ZERO filled
AT3000_user
Postby AT3000_user » 08.07.24, 08:55
Hello friends,
This is the second time I've received a Seagate ST2000DM005 drive in which the client claims there was a lot of data and the hard drive simply stopped operating. When I investigated, it appears to be a wiped hard drive. Given that this is an SMR drive, does anyone know what the most likely scenario is for what happened to it? Valid MBR existed and everything was zero.
Is there any chance to recover data from this drive?
Masterclass
Re: Seagate ST2000DM005 gone ZERO filled
Postby Masterclass » 08.07.24, 11:25
Clean MCT
AT3000_user
Postby AT3000_user » 09.07.24, 01:23
Masterclass wrote:Source of the post Clean MCT
Thank you Masterclass.
How to do that?
AT3000_user
Postby AT3000_user » 09.07.24, 01:41
Are you referring to this terminal command?
>CU10
AT3000_user
Postby AT3000_user » 10.07.24, 01:12
I cleared MCMT table using the U10 command. Repowered, still all zero.
