help to recover data from sd card 512gb
Help in recover Lexar 512 as seen not detected over any reader or over pc3000 flash sd card adapter
Re: help to recover data from sd card 512gb
Hello. You need to remove the plastic cover. Most likely it's based on two BGA-132 + SM2704
It’s like that like there is sealed or protective no chip appeared
In such case any solution to remove protective cover or in this case using spider board ?
Can you guide me in such case what we will do ?
You should grind the bottom side of the monolith and try to find the target layout.
