Seagate ST1000LM035-1RK172 - Capacity 0
Bio
Postby Bio » 29.05.24, 15:49
Hi guys
I have patient Seagate
Model: ST1000LM035-1RK172
FW: EB01
PN: 1AK172-570
Capacity: 1TB
ROM: Patched OK - without any problems
SA Backup: Done - without any problems
Access to SA MCMT or sys. file 0x93 - without any problems
Access to sys file 0x28 in ATA Indirect mode end with BSY mode.
Imo translator is damaged so what can i do to access user area ?
Log:
Switching HDD power supply ON
Selected family......................... : AF, Rosewood_AF
Model by ID............................. : <HDD ID NOT READ>
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ R1AEA0684.SDM4.AA4901.
Detecting SA Phys Sct Size...
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 2
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC : enabled
MC Size : 0x0
MC MCMT Ver is unavailable!!!
ID Len
0 40 Reserved Defect Table (SA defect table)
1 8 Drive Information File (DIF)
3 7800 Primary Defect File (P-List)
5 8 Manufacturing Information File (MIF)
8 4800
B 1000
C 122880 Serial Port Test Results File (Self Scan Log)
D 160
F 224 DIC Dummy File
15 128 BGMS File (Directed Offline Scan)
16 8
17 40
19 32 Log File
1A 40 Log File
1B 8 Log File
1C 16
20 384 Physical Overlay File 3
21 256 Physical Overlay File 4
2A 16 Saved Mode Pages (HDD settings)
2B 2008 R/W Operating Parameters (translator, etc)
33 4576
37 6800
3A 8
3C 616
3D 3584 Disc firmware container 1
3E 3584 Disc firmware container 2
3F 4576 SED parameters
40 184 SED parameters
41 2184 SED parameters
42 4096 ST Ovl
43 5128 Defect list report file
44 462568 BIG file
45 302752 BIG file
46 142368 BIG file
47 592 BIG file
48 232 BIG file
49 8312 BIG file
4A 8312 BIG file
4B 4352
4F 8192
50 30560 MCMT
52 8
58 12800
5C 2048
Collecting DT Infos...
ID MemOffs Len
0 80400000 230400 Read Adaptive Parameters File (RAP)
1 80439400 512 Controller Adaptive Parameters File (CAP)
4 118B00 8192 Servo Adaptive Parameter File (SAP)
80000000 16
total 8208
A 475BF8 1024 Seek Profile
13 80459CD0 2448 Dependent Zone Table for User Area
14 8045F668 32 Dependent Zone Table for System Area
15 0 1048576 Flash ROM
1D 80400020 5000 VBAR Configuration File
1E 804028A8 9680 Zone Format Parameters File
26 80452E20 28336
27 80452D00 288
ID MemOffs Len
2 804013A8 4832 Zone Table
80000000 16
total 8208
6 19D54E0 81940 Servo Flaw Table
16 80400000 32 Drive Configuration Table
17 804061A8 4848 Temperature Control Configuration
1F 80840B80 17136 RW working user preamp table
20 80844E70 112 RW working system preamp table
22 81639000 692224
25 816E2000 315392
26 80452E20 28336
27 80452D00 288
28 815E6000 327680
39 80D6DB80 2228224
3E 8045C1E8 13440
3F 8045F688 480
Collecting DT Infos completed
Buff Root FAT searching in RAM......... Ok
Searching volume 1/2 file table in RAM... Ok
Searching volume 4/5 file table in RAM... Ok
Request for volume 9/A file allocation table in RAM Ok
Searching CFW OVL FID in RAM............ Ok
Search for DBA Base in RAM.............. Ok
Search for RW Sys File DBA in RAM....... Ok
Search for MCMT RAM FD in RAM........... Ok
Terminal:
Boot0x80M
TCC:001B
Tech Unlock Handshake: 0xB670D957
Reply:
QB
Rst0x80M
T:0x0000 0x0A7258B0
FTU
TCC:001B:0028 EMCDataErr:00000013
SIMFileFD=FC379132ErrorCode=444400DFDiscLBA=000000000000A04EDuration=00000D59ms
SIMError1002LBA000000000000A04EFDFCFFF3FF
RWError444400DF
SIMFileFD=FC38A137ErrorCode=444400DFDiscLBA=000000000000A04EDuration=00000D5Ams
SIMError1002LBA000000000000A04EFDFC38A137
RWError444400DF
6GbMaxSpeedloweredto3GbforIntelbug
SendStatus:COMRESETseen
CSpd=3Gbps
FIS34
EDACValue=00000000FFFFFFFC
SIMFileFD=FC38630AErrorCode=44090082DiscLBA=0000000000008F9EDuration=0000082Bms
Re: Seagate ST1000LM035-1RK172 - Capacity 0
Postby digitalsupport » 30.05.24, 08:14
Read both copy of 28, if needed by one sector.
Combine and reconstruct a good 28 and load to RAM.
DRCSL
Postby DRCSL » 04.06.24, 15:19
Hello friend,
Did you get a solution to this question ?
I also got a hard drive with this problem, do data recovery..
