ST3000DM007 FAIL Servo Op=0100 Resp=0003
DRNZ
Postby DRNZ » 29.03.24, 03:03
Model : ST3000DM007
Serial : ZFN0WLXZ
Firmware : 0001
Capacity : 3 TB (5 860 533 168)
Hello All,
I'm gearing up to replace heads on this drive, just wanted to confirm there is no know firmware issues that can also cause this.
Code: Select all
Boot 0x0100MAE000L0001
SpinUp
 0100 9000 0000 0001 0000 9000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
 ResponseFrame 1580 0000 0000 5500 0000 0000 0000 0000 08AF 0000 CE00 0000 CE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 0000 0004 8931 FFA8 007F 0011 0006 0004 Loop=007F
 ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 1883 0000 CE00 0000 CE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 0000 0004 8931 FDFE 007F 0031 0006 0000 Loop=007F
ajay.mudhgill
Re: ST3000DM007 FAIL Servo Op=0100 Resp=0003
Postby ajay.mudhgill » 29.03.24, 17:08
better to replace the heads,short cuts are not always favorable. good luck :thumbup:
