could you sombody help?
hanjongwoo
Postby hanjongwoo » 27.02.24, 09:02
Hello everyone
I Have a quseton of WD charger 2tb
I have WDC WD20SDRW-11VUUS0
and i transfer usb to unlock sata pcb
hdd sound is good and i can see
model WDC WD20SDRW-11VUUS0 and capacity of this hdd 2tb
and log shows like this
Family:................................. : Charger 2.5"
System controller (SoC)................. : 88i1053A0 0x(5460)
Cyl Count............................... : 384
ROM Data size........................... : 1024 Kb
Modules directory address............... : 0
SA SPT.................................. : 1860
SA defects assigned..................... : 4
ROM Modules:
ROM version............................. : 06.8MD
Module 4F F/W version................... : 0006008M
Overlay F/W version..................... : 06.8ND
Servo F/W version....................... : 04.09
Relocations............................. : 0 (3 833)
Read ROM DCM............................ : Ok
Power up load dir data.................. : Yes
Power up load permovl................... : Yes
Power up load CFG data.................. : Yes
NN | Step | Time | Flags | Info | Description
60 | 20C | 2.40 s | 141004012106CDFF | 51043307 | OVL_POWERUP_LOAD_DRM_FILES(SMART DRM LOAD DISABLED)
Service area:
Dir items loaded........................ : 613
CFG tech mode lock...................... : No
Self encryption drive................... : Yes
SED Info read........................... : Ok
Master Password......................... : No
User Password........................... : No
SED tech mode lock...................... : No
UA writing.............................. : Granted
DCM in module 47........................ : ZP
DCM in module 0A........................ : |R|NZPBC4F
DCM in module 02........................ : S|BRL|PNMZHPCBRCV4KUUG
To be able to create utilty based DE task, start "Prepare to get UA PBA
i clicked tool-sector edit but first sector is wrong
53 37 74 fd f2 71 9b 1c ae e0 7b 13 6c f5 c0 (like this)
iam not good at in englisk and pc3000
could you help me somebody?
have a good day
northwind
Re: could you sombody help?
Postby northwind » 27.02.24, 13:01
it's because Chargers encrypt data via MCU.
You changed PCB, so MCU is different, so data is encrypted.
You need to use original PCB (convert to SATA or use solderless PCBs or....)
hanjongwoo
Postby hanjongwoo » 27.02.24, 14:57
northwind wrote:it's because Chargers encrypt data via MCU.
thank you but original PCB is breaken
Postby digitalsupport » 27.02.24, 19:21
hanjongwoo wrote:Source of the post
If original PCB can not be repaired, then you need to transplant MCU.
