I have a WD Charger that just stuck on busy with the original ROM and unlocked ROM and with SATA PCB and with the original USB PCB converted to SATA. so I cannot use the function "Block SA Aceess" because it has to write the ROM directly into the HDD using SATA which is impossible while the HDD stuck on BSY.
is there a way to block SA access in ROM read from a file and save it also into a file so I can write it back using a programmer?
Block SA access from file
- digitalsupport
- User
Re: Block SA access from file
Read and write ROM with your external programmer does the job.
- LostDataSA
how to block SA access in ROM after reading it by programmer so I can write it back on PCB?
If I'm thinking right Isolate the heads, then wait for drive to get ready, then you can get in and block SA access. Just like on old Fblite drives, etc.
- LostDataSA
Isolate the heads worked this time but it took longer time than usual to get RDY
