Rom reading prb WD40NDZW-11A8JS1
eurlamp
Postby eurlamp » 03.07.23, 15:39
Hello everyone,
On this 2060-810035-001 pcb the rom is encrypted and the component ref is : IS25WQ040.
For reading rom externally and decrypt it, I'm using a CH341A programmer or the RUS V5000 but it doesn't recognize this Rom model.
Does someone could give me a bios programmer which is working with this component?
Best regards
François
SGdata
Re: Rom reading prb WD40NDZW-11A8JS1
Postby SGdata » 03.07.23, 16:13
Rom is not encrypted. Revelprog reads them easily.
Postby digitalsupport » 05.07.23, 16:12
+1 for Revelprog
fastec
Postby fastec » 22.10.23, 11:47
You can use CH341 programmer with a good software :-) e.g. NEO Programmer but you also need the tool to power the ROM at 1.8V which is an optional module usually not provided with the various CH341 s available on ebay
Most probably if you find the 1.8V adapter, you are already done
if not, together with the 1.8V adapter, search for NEO Programmer software
Return to “WD USB”
