WDC WD60EFRX-68L0BN1 VSC ERR INV FUNC CODE REQ"
Paulfromsurrey
Postby Paulfromsurrey » 10.06.23, 06:25
Drive WDC WD60EFRX-68L0BN1
Family Rembrndt
Drive shows up with no Serial no
Firmware no info
Capacity 0
System controller (SoC)................. : 88i1047F0 (5450)
ROM version............................. : 03.1TG
FlDir:.................................. : 20B
Phys - SA C:............................ : 256
H:...................................... : 1/0
S:...................................... : 4 960
UA C:................................... : N/D
Family:................................. : Rembrndt
Src..................................... : ATA2
Mode:................................... : Normal
HDD State:.............................. : Idle(0)
Drive shows busy
Techno mode key
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
System controller (SoC)................. : 88i1047F0 0x(5450)
ROM Data size........................... : 1024 Kb
Modules directory address............... : 533 335
SA Access check in RAM.................. : Static module reading error Device Error Detected: "VSC ERR INV FUNC CODE REQ"
Module 02 access........................ : Blocked
SA SPT.................................. : 4960
SA Translator loading................... : Module ID 30 reading error: HDD Redynes timeout (10000)
ROM Modules:
Module 4F F/W version................... : Module ID 4F reading error: HDD Redynes timeout (10000)
Overlay F/W version..................... : 03.1TG
Servo F/W version....................... : 01.0L
Head Map Reading Error.................. : Module ID 0A reading error: HDD Redynes timeout (10000)
Read ROM DCM............................ : Ok
Power up log reading.................... : RAM Table reading error: HDD Redynes timeout (10000)
Service area:
SA dir reading (ID)..................... : Techno key error: unexpected error: HDD Redynes timeout (10000)
Configuration reading................... : Module ID 02 reading error: HDD Redynes timeout (10000)
DCM in module 47........................ : Module ID 47 reading error: HDD Redynes timeout (10000)
DCM in module 0A........................ : Module ID 0A reading error: HDD Redynes timeout (10000)
DCM in module 02........................ :
Techno ON............................... : Techno key error: unexpected error: HDD Redynes timeout (10000)
Please let me know how we can get this drive fixed
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
Paulfromsurrey
Re: WDC WD60EFRX-68L0BN1 VSC ERR INV FUNC CODE REQ"
Postby Paulfromsurrey » 10.06.23, 07:21
I found this file you think this will work to upload corrupted or misssing modular
https://files.hddguru.com/download/PC-3 ... irection=1
WDC WD60EFRX-68L0BN1-82-00A82-WD-WX11DC6RD93L.rar
Paul Patil
PC Plus Computing
