How to unclok SSHD Seagate ST2000LM010 FW:SDM1
Hoang21
Postby Hoang21 » 04.05.23, 11:00
I have a Seagate ST2000LM010 FW:SDM1 SSHD hard disk that it blocks on BSY (I attach the log file in terminal)
I can't read SA or enter Terminal with Ctrl+Z, I read article PC-3000 for HDD. SSHD disks to unclock
https://blog.acelab.eu.com/pc-3000-for- ... -work.html
In Work With Flash Rom image file, I chose: Kahuna CFW patch 1"
It shows error in log:
Error correction ROM data
Error: Can't find patch point 1!
"Kahuna CFW patch 1"............................................: Error
If I choose: Kahuna/GrenadaSSHD CFW/DFW patch 2
"Kahuna/GrenadaSSHD CFW/DFW patch 2"........................: Error
How to unlock SSHD Seagate ST2000LM010 FW:SDM1 ?
Thank you for your help
log.txt
(13 KiB) Downloaded 533 times
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
northwind
Re: How to unclok SSHD Seagate ST2000LM010 FW:SDM1
Postby northwind » 04.05.23, 16:35
Yes, that's because this drive is not a Kahuna.
Additionally, I don't think this drive is an SSHD.
Hoang21
Postby Hoang21 » 04.05.23, 16:53
I tried to also do the path Rosewood, it displays in terminal
Boot 0x80M
Tech Unlock Handshake: 0x11CA1E90
Reply:
but I can't enter Terminal with Ctrl+Z,see my log file.
Do you have the solution ?
log2.txt
(11.83 KiB) Downloaded 485 times
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
zeroalpha
Postby zeroalpha » 16.11.23, 05:32
Did you try to short pcb to get a terminal access?
