WD Green SSD 20-82-00469-2 (SM2258XT) Short pins
alphageeks
Postby alphageeks » 08.12.22, 13:09
Can someone please tell me where short pins (safe mode) are located.
Photo attached
Thank you
compressjpeg.zip
(1.61 MiB) Downloaded 1567 times
Re: WD Green SSD 20-82-00469-2 (SM2258XT) Short pins
Postby Roman_TS » 11.12.22, 18:27
WD Green can be based on 5 different CPU platforms:
1. SM2258XT
2. Maxiotech
3. Sandisk 82-00-469
4. Lexar DM918
5. Realtek RTK
We can deal with SM2258XT modification, while Maxio and Sandisk modifications are not supported.
Sandisk 82-00469 is a native Sandisk CPU which isn't connected with SM2258XT controller.
alphageeks
Postby alphageeks » 12.12.22, 00:51
Thanks for you response, any idea when it may be supported?
Postby Roman_TS » 12.12.22, 09:18
It's still possible to recover data via Chip-Off, but:
1. NAND chips must be configured in PC-3000 Flash for a correct CE for LUN reading. As the result, you may get a dump with 50% zero sectors after first 50% of DA.
2. There would be a massive number of bit errors, so we should prepare for rereading;
3. Image Building will not be possible, because CPU algorithm is using a lot of different sub-blocks, update-blocks and translator tables to address everything;
4. The only possible result - is a RAW recovery, without Folder Structure. And most likely a lot of data will be damaged with ECC.
At this moment, our developers are working under Sandisk CPU researching to add the native Sandisk CPU-based drives into support list. But at this moment, I'm afraid, we don't have an approximate time when it would be ready.
c.vogl@solution.at
Postby c.vogl@solution.at » 01.02.23, 19:50
is it also possible to swp the controller? or is it encrypted unique?
Postby Roman_TS » 02.02.23, 10:57
The main problem of the failed SSD is a damaged Firmware (translator part). So, the question is - how the controller swap will help you?
All unique information is located inside the NAND chips (firmware is located in Service Area - reserved pool for storing service structures and the main firmware). If the problem is inside the FW, then CPU swap will not help you - damaged firmware would be still the main reason of the SSD fault.
NAND swap from damaged SSD to a good donor is recommended only in case if the original PCB has serious issues with the electronic components.
Postby gameboybin » 30.07.23, 11:42
Roman_TS wrote:Source of the post It's still possible to recover data via Chip-Off, but:
Hey Roman! Should the chips be automatically ID in the PC3000 Flash. Just wanted to get the dumps out
Screenshot (592).png (308.3 KiB) Viewed 22780 times
Postby Roman_TS » 30.07.23, 22:10
There is no ID at all in your case. Chips are not reading. I recommend you to clean the bottom side of the NAND and try again.
