General question SONY Formatted SD, microSD cards
Typical Flash recovery cases
Postby gameboybin » 27.10.22, 03:40
Hi everyone,
So i have encountered many cases with SONY, FUJI, CANON (New cameras) Formatted Flash cards.
It uses some kind of TRIM to make whole card become 00
Is it possible to recover all the formatted data??
If yes, then how?? ( Just want some general answer to unerstand the situation more clearly. Like how did the Camera formatted it. What does it take to recover the formatted files??)
Thanks!
SGdata
Re: General question SONY Formatted SD, microSD cards
Postby SGdata » 27.10.22, 06:33
In most cases they can be recovered by reading over NAND protocol.
Postby Roman_TS » 27.10.22, 12:09
Formatting command in camera erase the translator, which makes data turns into zeroes. But as SGdata mentioned, it's possible to recover it via NAND protocol (using chip-off)
Postby gameboybin » 27.10.22, 13:12
Roman_TS wrote:Source of the post recover it via NAND pro
Thanks, i will create a ticket. Hopefully someone could help me out
